Engine Missing in Closed Loop only.
Old Oct 24, 2008 | 07:47 PM
derekiroc's Avatar
Engine misses in Closed Loop. No codes as of yet. At low throttle engine will miss and at 1/2 to full throttle it starts to backfire when you let off the gas like its getting lean conditions. What sensor should I replace first, Knock sensor, Temp etc... Need some where to start.
Old Oct 24, 2008 | 08:00 PM
redbird92''s Avatar
Car: 92' firebird
Axle/Gears: 10 bolt POSI 3.73's
Re: Engine Missing in Closed Loop only.
You can start with getting a new 02 sensor. I personally like the GM heated ones.
Your 02 controls closed loop fueling
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
MY87LT
Aug 17, 2015 08:43 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
IROCThe5.7L
Aug 10, 2015 11:24 AM
