TPI Z28 shutting off
Old Oct 30, 2008 | 05:24 PM
elcaminobill's Avatar
Having problems with a 91 Z with 305 TPI shutting off. It will start afterwards with starting fluid. It seems to be a fuel delivery problem. I also surges some while driving.
Injectors have been cleaned
Fuel pressure checked good
No codes or check engine lite
EGR recently changed
Fuel filter changed
Spent lots of $$$ but local mechanics are getting nowhere.
Old Oct 30, 2008 | 06:37 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
Re: TPI Z28 shutting off
When is it shutting off? Idle, coasting, full throttle, etc.? I would ohm the injectors when they are cold and again at operating temp. Check for vacuum leaks, those hard plastic vacuum lines are sneaky, they may be cracked just enough that you really have to look to see the problem.
1992rs/ss
Jan 31, 2025 05:10 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
wayshegoes
Aug 17, 2015 12:00 PM
Sanjay
Aug 12, 2015 03:41 PM
Fronzizzle
Aug 9, 2015 01:15 PM
