Need a lil input... 2 options.
Old Nov 6, 2008 | 12:53 PM
boldguy's Avatar
Car: 1992 Z28
Transmission: World Class T-5 5speed manual Trans
Axle/Gears: STOCK G92 performance 3.42
So i have a 92 z28 350 TPI 5 speed manual, and it has the stock 305 PROM and the stock 305 19 lb injectors. My options are:
1. Tune it for the 19 lb injectors and the more displacement via a new PROM.
or
2. Get a new PROM for bigger injectors, higher pressure and more displacement, and then get new injectors and then install that PROM..
Need some input,
Thanks guys.
-Boldguy
Old Nov 6, 2008 | 05:12 PM
boldguy's Avatar
Car: 1992 Z28
Re: Need a lil input... 2 options.
or how about this one,
What size injectors should i get??
1. 21 lb/hr
2. 23 lb/ hr
3. somewhere in between???
What brand???
any input good or not is greatly appreciated.
Old Nov 6, 2008 | 05:23 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
1. 21 lb/hr
2. 23 lb/ hr
What brand???
I have 29lb Acel on my 89 GTA with an adjustable fuel pressure regulator I would go that way.
Old Nov 6, 2008 | 05:49 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
I had a TPI 350 running on a 305 prom for awhile, eventually installed
Ford 22lb injectors and tuned the car when I was ready.
Id rather have the car tuned when everything is in place rather
then tripping over yourself later. Id wait till you have the modifications
in place then have the car tuned.
So the number 2 option is not very logical
As for injector size it all depends on what your plans are for the motor.
Old Nov 6, 2008 | 06:23 PM
boldguy's Avatar
Car: 1992 Z28
Awesome! Thanks guys for the input. I have been doing some research this whole time and i have heard that the Accel injectors are not very reliable. I only want to do this once (maybe twice when i have to smog again ) I think i will get the Ford 22# injectors and have the pressure regultor at 45-48 PSI, then get a chip burnt. Also to my knowledge ford rates the injectors at 39psi??? So with the fuel rail at 48 psi they would flow more like 24#'s??
The only other brand that caught my eye was Racetronix...
Any potential Problems to speak of??
Thanks again!
Old Nov 7, 2008 | 01:15 AM
boldguy's Avatar
Car: 1992 Z28
I thinks i will go with the Ford Yellow top injectors, 22 lb/hr at 43.5 PSI.
http://www.fiveomotorsport.com/FMC_Compete-Set.htm
They should be just a plug and play and i'll be rippin through the gears like no ones business
Let me know what you guys think.
i have emailed fiveomotorsport and they shouold get back to me, i will let you guys know what they think.
thanks again
Old Nov 7, 2008 | 03:49 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Call John at FIC: Tel: 770-888-1662. Get the 22lbs bosch design three with the modified base to fit our cars. They only cost $170 and have a 3 year warranty and are probably some of the best injectors on the market. Get a chip for a speed density 350 and run stock fuel pressure. This way you can drive the car without major issues and do a custom tune when you are done modifying it. Just my .
Old Nov 7, 2008 | 01:25 PM
boldguy's Avatar
Car: 1992 Z28
Heres what five o said
"Kevin - You can go with a 24lbs/hr Ford Racing fuel injector. We sell the
sets for $322.50.
Bruce Holt,
Fiveomotorsport"
and then i will get a prom burnt...
Old Nov 7, 2008 | 03:53 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Do this one and save money and a better injector
seiplentz
Aug 19, 2019 06:02 PM
gixxer92
May 18, 2017 11:20 AM
Racerx974
Sep 19, 2015 10:16 AM
383cam
Sep 9, 2015 06:01 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
