Jump ECM pins A and B 305 TPI runs fine???
Old Nov 7, 2008 | 01:35 PM
jshepit's Avatar
Car: 1988 IROC
Transmission: BW 5-Speed
Axle/Gears: 3:73
What does the ECM do when you operate the car with pins A and B are jumpered? With out them jumpered I get intermittent hesitation at take off through all gears, if I jumper A and B it runs great. SES seems to indicate that is is transitioning from Open loop to Closed loop after warm-up, but I'm still not sure what change jumpering A and B has on the ECM.
Old Nov 7, 2008 | 05:44 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
Re: Jump ECM pins A and B 305 TPI runs fine???
I think it put the ECM in "Feild Service Mode"...and disables several feedback functions from the sensors to the ECM to operate as designed.
So....when you jumpered A and B, before you start it, did you get any codes?
Old Nov 10, 2008 | 11:51 AM
jshepit's Avatar
Car: 1988 IROC
Axle/Gears: 3:73
I did get the codes. They were 21 (TPS Volt Hi, but it checks out ok), 33 (MAF (gm/sec HI) not sure how to test MAF and code 54 (which is fuel pump circuit) this has been changed and fuel pressure good. The engine runs no better/or worse if I disconnect the MAF. I've replace the MAF power and burn-off sensors with not change. Do you think the MAF is bad?
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
Brcharrelson
Aug 26, 2015 07:47 PM
st.evel07
Aug 13, 2015 06:15 PM
Sherpajames
Aug 7, 2015 06:56 PM
