Ford injectors
Old Nov 17, 2008 | 05:06 PM
wild28's Avatar
Ford injectors
I bought the scroggin dickey SD360VTPI engine. I am using the original fuel rails. They sent me 24lb ford racing injectors. The injector retainer clips that hold the originals in the fuel rails will not fit the ford injectors. I called scoggin and they said they have been using the same injectors for that engine for years and no one has ever called about these retainer clips not fitting. Can I run these injectors with out the clips? Is it possible I have the wrong injectors. They swear up and down I have the right ones. they have 223523 on the back and 0 280 155 931 on the side. They look exactly like the ones in this picture.
Old Nov 17, 2008 | 07:09 PM
vipershark11's Avatar
Car: 92 trans am clone
Engine: LO3
Re: Ford injectors
weird looking injectors ive never seen them like that but theyre probably right. also the electric plug socket is correct so thatll be fine and you shouldnt need the retaining clips i didnt even use them on factory injectors and no leaks.
Old Nov 17, 2008 | 08:09 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Ford injectors
that is a design 3 bosch,, great injector,, same one on the ls1 stock.. no need for the clips. they wont leak
Old Nov 17, 2008 | 08:32 PM
gtp-1's Avatar
Re: Ford injectors
Yep, forget the clips. The new style injectors rock. You got some nice units there, PM me what you paid if you will.
Old Nov 17, 2008 | 11:28 PM
southbay08's Avatar
Re: Ford injectors
When running 43.5psi fuel pressure, it holds them in place. No need for clips!
Great injector, we have gotten nothing but postive feedback on them!
www.southbayfuelinjectors.com
Old Nov 18, 2008 | 06:57 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Re: Ford injectors
You will not have any problems with that combo. I have had that exact same engine, fuel rail, & injector combo on my car for almost six years now without any issues. The retainer clip isn't really needed after everything in installed. They're there to help keep the injectors in place during installation. After the rails are bolted down, the clips aren't really needed.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Veaceonee
Sep 29, 2016 08:15 PM
92-Formula
Dec 12, 2015 10:34 PM
webeeZ28
Sep 14, 2015 12:00 PM
