Help!SLP runners don't fit?
Old Nov 24, 2008 | 01:12 PM
ch@0s's Avatar
I bought runners from aforum member. said to fit 89-92 TPI
https://www.thirdgen.org/forums/engi...p-runners.html
I put them together with my plenum and bigmouth intake for a test fit.
I have a 1991 corvette speed density set up. At first I thought I had 2 left sides but now I think I may have the wrong runners. The odd thing is if they were the wrong runners wouldn't they have a cold start injector hole in them.
The problem I have is there is what looks like egr passage on both runners. My stock runners only have it on one side.When I bolt it together ther will be a leak as one of the passages is clearly vissible from the underside of the plenum.
What do I do. Can I just jbweld thet extra runner closed?
Old Nov 24, 2008 | 01:32 PM
Brisk's Avatar
Car: '88 IROC-Z / '91 Z28 / '91 GTA
Engine: LT4 Hot Cam 305 / L98 355 / MR 383
Transmission: 5-spd / 700R4 / 700R4
Axle/Gears: 3:45 / 3:23 / 3:23
Re: Help!SLP runners don't fit?
sounds like you have two right sides, not a left and a right??
Old Nov 24, 2008 | 02:11 PM
ch@0s's Avatar
I thought that too but then I swapped them form one side to the other and I
noticed the right side top has an angle to follow the angle of the Plenum where the TB goes..
Old Nov 24, 2008 | 04:31 PM
Abubaca's Avatar
yeah, the one runner set has the angled front piece.
I've never inspected SLP runners closely, but are you sure that extra runner actually goes all the way through? Meaning....could it already be closed off?
I'd probably have it welded as opposed to JB. hate to have something come off and go into a cylinder.
Old Nov 24, 2008 | 05:32 PM
F-Body Demon's Avatar
+1. How much would that suck
Old Nov 24, 2008 | 06:06 PM
ch@0s's Avatar
here is a pic
I think maybe SLP used the same casting for early and late and the prvious owner put these holes there for his 87
Old Nov 24, 2008 | 06:20 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
If you want to sell them let me know. I think I know of a buyer.
Old Nov 24, 2008 | 09:27 PM
Brisk's Avatar
interesting.. looks like those made it out of manufacturing without a close inspection. just weld the holes, no harm.
Old Nov 24, 2008 | 09:34 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Send them to me and I will weld them shut for free. Just for the cost of shipping them back to you...
Old Nov 25, 2008 | 08:18 AM
ch@0s's Avatar
I might take you up on that. I have someone local that might be able to do it. If not I will send them to ya. Thanks a bunch!
Old Nov 25, 2008 | 12:44 PM
ch@0s's Avatar
ok, they have been welded.
with that out of the way What is your opinion on fully porting the runners.
Does anyone know why they siamese half the runners and leave the others alone?
VEH Specs: 1991 vette, ADS Super Chip, SLP ported runners, TPIS Bigmouth intake, ported intake, Accel ignition, Bosch III injectors 19#, AFPR, Flow master cat back. plan on replacing springs maybe 1.5 rollers .
cam .495 INTAKE LIFT / DUR.@.050 .218 DEGREES
.502 EXHAUST LIFT / DUR. @.050 .224 DEGREES .
long tubes and 307 gears are in the future plans
Old Oct 14, 2021 | 06:49 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
I know this is a older post but figured I'd add some info after I dug it up looking for something else.
The driver side runner needs the small tube plugged for use on 89-92 tpi. SLP threaded each end of that port and included a couple pipe plugs in later years. Was easier to make 1 casting and do a few extra machining operations for different year splits 85-88 and 89-92.
Old Sep 23, 2025 | 06:43 PM
LoudmouthSS's Avatar
Car: 1991 Z28
Engine: SBC
This post just saved my ***. As these cars get older this info gets lost. Idc how old this thread is..its getting a response.
Jeremys87
Jul 14, 2022 09:08 PM
tazs2000
Jul 15, 2017 08:44 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
89lsc
Aug 14, 2015 04:58 PM
