Injectors leaking at fuel rail.
Old Dec 14, 2008 | 11:46 PM
hotrodta57's Avatar
Car: 1988 T/A
Engine: L98 Highly modified
Transmission: TCI 700R4
I have 30Lb Venom injectors in my L98. I have replaced the o-rings twice, but keep getting leaks at the fuel rail. The last o-rings were GM factory blue Vitons. Was thinking of going with different injectors, probably back to 22Lbers. Any thoughts?
Old Dec 15, 2008 | 12:18 AM
92droptopws6's Avatar
Car: '88 Trans Am
Engine: 5.7L TPI
Transmission: Slushbox
Re: Injectors leaking at fuel rail.
i have some Lt1 24s that have 89k on them,i will let go for 40.00 shipped
Old Dec 15, 2008 | 04:25 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
What was the reason for the 30# injectors? Running boost? Anyway, make sure the fuel rails are clean too. You might have something in there that could be causing the leaks. Also, make sure the o-rings are in good condition when putting them in the holes. Use a silicon base lube spray to help get them in easier.
Old Dec 16, 2008 | 04:48 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
It's also possible that part of the injector is cracked.
Old Dec 16, 2008 | 08:25 AM
hotrodta57's Avatar
Car: 1988 T/A
At the time I didn't how many horsepower the stock injectors would support. When I rebuilt the engine I carefully cleaned the fuel rails. There is leaking from more than one injector also. Will probably go with a matched set of 22# from FIC anyway. Thanks for the ideas!
Old Dec 17, 2008 | 10:11 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Transmission: 4 spd auto
Did you use the injector locking clips or leave them out?
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Infested
May 22, 2018 11:56 PM
justin57
Aug 20, 2015 07:05 PM
djmarch
Aug 9, 2015 05:27 PM
