Surging @ cruising speed.
Old Dec 27, 2008 | 09:32 PM
86 Cali IROC's Avatar
Car: 86 IROC spts cpe conversion.
Engine: 89 L98 TPI since 2000.
Transmission: NOW A T-5 as of 3/19/08
Axle/Gears: 373s
This is happening on my car, as well as my cousins car.My car L98 350 TPI Full tune up / with injectors.http://imaging.lefora.com/reduce/?ur...a15e0/cam2.bmp Starts great.accelerates great. while at cruising speeds the car begins to surge wether it's in first or 4th.I have to accelerate to relieve the surge. He has a 305TPI. I have the 350. Any suggestions?Both cars have had full tune ups. fuel filters, plugs, wires, caps, rotors, and coils. Mine has new 20lb injectors
http://imaging.lefora.com/reduce/?ur...307e1/cam1.bmp
Old Dec 28, 2008 | 11:51 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Surging @ cruising speed.
It could be one of 50 different things, but since you've already replaced the injectors and the fuel filter, I would guess you have an intermittent open in the fuel injector wires.
Old Dec 29, 2008 | 12:12 AM
Axle/Gears: 373s
Do you think it could be the pressure regulator? Would a variance in the fuel pressure do this kinda thing?
Old Dec 29, 2008 | 12:16 AM
mnorton's Avatar
Car: Red 1987 IROC Convertible
Engine: 305 LB9 TPI
Transmission: T5 5-Speed
Axle/Gears: 9-Bolt 3.45
Yes! Do you have a Holly AFPR? Because they SUCK! The diaphragms tear!
Old Dec 29, 2008 | 09:44 PM
cmgrinn's Avatar
Car: 91 Z28
Engine: 5.7 L98
Transmission: 700r-4
Axle/Gears: 3.43
Does it happen with the A/C compressor on? Or does it happen at all times?
Old Dec 29, 2008 | 10:03 PM
Axle/Gears: 373s
It happens all of the time. whether or not the AC is on. Now, both cars have NOT had the regulators replaced. They're original. And or, would this be a symptom OF a bad regulator?
Old Apr 1, 2010 | 08:51 PM
tealcamaromanrs's Avatar
Car: 1991 camaro z28 convertible
Engine: 383 tpi
Transmission: t5
i am having the same problem any other ideas.......i have new jet fuel pressure reg...so i would doubt its that
Old Apr 1, 2010 | 11:31 PM
StevenB L98/LS1's Avatar
Car: 1989 Firebird Formula
Engine: 5.7 LS1
is it speedy density or maf? could be possible the ECM could be showing signs of going bad, its rare, but ive seen it happen. id check the fuel pressure, or check the vacuum lines. sounds very weird though
Old Apr 4, 2010 | 07:47 PM
Engine: 383 tpi
Transmission: t5
found out problem it was map sensor changed it and now runs great
Old Apr 5, 2010 | 12:05 AM
FFCam1991's Avatar
Car: 91 Formula
Axle/Gears: stock
My 91 305 TPI has had the exact same problem for years! It's especially bad around 1000-2000 RPM, in the lower gears. Was your car giving you any codes? Just wondering how you knew it was the MAP sensor. I've changed CTS and O2, car has good tune up, 18 inches of vacuum, 40 psi fuel, no codes, etc.
I don't know about your car, but mine thuds back and fourth as the revs bounce about, its extremely annoying.
I'm seriously out of ideas, was about to post a new topic but I'll see if there is any additional info here.
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
tattmann
Sep 27, 2015 05:20 PM
