305 Fuel Injector question
Car: 88z
Transmission: t-5
So my intake gasket decided to go the other day, and I noticed a nice little pool of coolant that had seeped out on to the intake manifold. I start to unbolt the TPI and fuel rail and noticed I have two injectors that are pretty filthy. The engine is a stock 305. Do you recommend I get the stock 19lb injectors or has anyone upgraded to the 22lb? Anyone know the difference (besides price) of these 19lb injectors?
http://fuelinjectorconnection.com/sh...d&productId=60
http://cgi.ebay.com/ebaymotors/FIC-F...Q5fAccessories
Will these fit with no modifications?
If you recommend something different, please do not hesitate to share.
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
Re: 305 Fuel Injector question
I believe the first set of Blue Demons are FIC's brand of injectors and the second set are Bosch II injectors(older version). Both will work fine and are direct fit.
Most people on this forum like the Bosch III's for $169, call Jon at FIC, he is graet and will gladly help you choose the right 19lb injector for your car.
For the record, I purchased a set of the Bosch II injectors last year for $124, my 305 car runs like an animal .....
I would maybe upgrade to the Bosch III's based on the rave reviews from this forum. I would check if the Bosch III's are 19lbs, if they are 22lbs, you may have to change your chip.
Again, call Jon at FIC, he will do you right...
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Get the Bosch Design III from FIC. I have them in my 305 and it runs very well. Start right up. I got the 22 lbs injectors, but my computer has been programmed to run with them. Without prom tuning you will need to stick with the 19 lbs injectors. Call John at FIC, he will take care of you. With the intake runner gaskets and shipping my total cost was around $220. It's some of the best money I have spent on this car.
Car: '89 Formula WS6 N10 No T-Tops
Engine: LB9 225HP
Axle/Gears: 3:45BW
Car: 87 Z28
Engine: 89 tpi soon tpis big mouth & tubes
Axle/Gears: 3:43
Whats the difference between the bosch 2's & the 3's. my bosch 2's came with the 4 hole plates. & are they as noisey as the stock injector.
Engine: 305TPI
Car: 89 T/A
Engine: LB9
Transmission: W/C T-5
Axle/Gears: 10 bolt posi, 3.73 Richmond Gears
Jon advised that the 22's will work with the stock LB9 ECU and when you do any engine upgrades down the road your good to go with the 22's.
Engine: 305TPI
Make sure to program your computer for them. You have to change the injector constant.
Car: 89 iroc
Engine: l98
Transmission: tremec
NOT IF YOU JUST LOWER THE FUEL PRESSURE TO 38.. THATS WHAT I ALWAYS DO WORKS FINE. BUT YOU HAVE TO HAVE A AFPR. IF YOU DON'T THEN GET THE 19 AND THEN IF YOU DO MODS AND HAVE TO GO BIGGER THAN YOU HAVE TO BUY ANOTHER SET,
Car: 89 Trans Am
Engine: 5.0 TPI
As I said earlier, if you get the Bosch III's you will have to reprogram your chip. If you want to stay stock, go with the Bosch II's, this way you won't have the added expense of AFPR's and reprogramming chips. Jon will tell you the II's are good injectors, the only difference is Bosch III's spray with better atomization and are a newer version.
I have the Bosch II's and my 305 runs great...just my 2 cents.
Car: 91 Z28
Engine: LB9
Transmission: 5 speed
Axle/Gears: 3.73 limited slip stock
ive purchased a set of type 3 injectors rated for the stock 19lb of my car do i still need to have my chip reprogrammed??
Car: 89 iroc
Engine: l98
Firechicken86
Aug 12, 2015 10:07 PM
