305 rebuild
Old Jan 12, 2009 | 06:25 PM
86firebirdta's Avatar
Car: 1983, 1986, 2001 Trans Am
Engine: 305 cfi, 350 carb, LS1
Transmission: 700,Edge 2800 th350,Edge 3400 4L60E
Axle/Gears: 9 Bolt 3.27 Borg-Warner, built 3.73
305 rebuild
I have an 86 trans am LB9 not lookin to go for a 350 or nothin else jus wanna keep the 305 in it and am lookin for suggestions on wat to do to it when i get it rebuilt i have already installed 1.6 roller tip rockers in it and am lookin wat will go good with it any suggestions thanks
Old Jan 12, 2009 | 06:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: 305 rebuild
What's been done to it already? Why are you getting it rebuilt?
Old Jan 12, 2009 | 06:31 PM
Re: 305 rebuild
i got 1.6 rockers jet stage 2 chip bbk fuel pressure regulator and fuel pump jus basic stuff im wantin to put a cam in it and bore it 10 over from wat i have heard is the best way to go with the 305s
Old Jan 12, 2009 | 06:33 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 rebuild
Boring an engine when it doesn't need it is a waste of time and money.
Do you have headers on it?
Old Jan 12, 2009 | 06:36 PM
Re: 305 rebuild
no that was somethin i was goin to put on when the motor was outside lil bit more room to play around with you kno
Old Jan 12, 2009 | 06:42 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 rebuild
Put headers and exhaust on before you do anything else.
Old Jan 12, 2009 | 06:49 PM
Re: 305 rebuild
i got a 40 series flowmaster on it i drive a truck everday so the ta is my weekend car so im lookin to do this right now
Old Jan 12, 2009 | 06:52 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 rebuild
Have you got a catback too, or just the muffler?
Old Jan 12, 2009 | 06:54 PM
Re: 305 rebuild
jus the muffler im wantin to go to true duals after the rebuild i took off my y pipe and started her up and jus sounded like a beast so i think thats wat ima do when the time comes
Old Jan 12, 2009 | 06:55 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 rebuild
Not if you need to pass California emissions.
Old Jan 12, 2009 | 07:35 PM
Re: 305 rebuild
why wouldn it if you had the cats and mufflers on it should pass no problem
Old Jan 12, 2009 | 08:06 PM
<3myZ's Avatar
Car: 92 Z28
Engine: built 307 w/ 100 shot
Transmission: 700r4 w/ shift>>kit
Axle/Gears: 3:73
Re: 305 rebuild
i bored mine over .30 and you can really tell, put a slightly bigger cam, valves, etc. and i beat 350's all the time. boring the motor is a good idea i have mine set up for nos and i run with ls1's. just make sure you have a good flowing set up. headers and exhaust are huge if you are doing cam swap. glad to see someone else believes in the lb9!
Old Jan 12, 2009 | 08:14 PM
Re: 305 rebuild
wat would an ideal cam for my car
Old Jan 12, 2009 | 08:20 PM
<3myZ's Avatar
Car: 92 Z28
Axle/Gears: 3:73
Re: 305 rebuild
it depends what you are looking for daily driver, street strip, or track only. but it is important to have all the other components that will work with the cam you want. from heads to headers and even a decent stall converter. there is alot to take into consideration for a proper cam swap.
Old Jan 12, 2009 | 08:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 rebuild
I doubt you can really tell the difference from boring alone. Boring a 305 .030 over increases the displacement by a whopping 1.6%. Hardly cost-effective when there are sooooo many things you can do a lot more easily for a lot less money that actually do make a difference. Boring is to correct cylinder-wall wear, not to make power.
Old Jan 12, 2009 | 08:25 PM
Re: 305 rebuild
jus lookin for a mild cam nothin too big out of the ordinary like i said it has 1.6 rockers in there right now and im jus lookin for a fun weekend car thats got some ***** to it
Old Jan 12, 2009 | 08:44 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: 305 rebuild
You only have 1 catalytic converter right now. California won't let you add a second one for dual exhaust.
Old Jan 12, 2009 | 08:51 PM
Re: 305 rebuild
i kno that jus when the time comes tho that was my idea for the exhaust was true duals
Old Jan 16, 2009 | 10:27 PM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Re: 305 rebuild
What ever you decide to do with the cam, make sure you get the heads cleaned, new springs put on and get some screw in rocker studs. The stock pressed in studs WILL come out. It happened to me when I was just learning about this stuff 8 years ago. Mr Gasket makes a good screw in stud that takes less machining than others. Summit Racing part # for these studs is MRG-1076. Also getting a valve job done would be a nice idea while you have them at the machine shop.
Old Jan 16, 2009 | 10:32 PM
Beltfed's Avatar
Car: '86 Trans Am
Re: 305 rebuild
Really? I thought there was some way around it with like a cross over pipe or something. I've got the same car as this guy, and even the same color but mine is a 5 speed. I'd like to mod mine up too.
InfinityShade
Feb 21, 2016 01:29 PM
fbirdroller
Sep 2, 2015 10:27 PM
someone972
Aug 30, 2015 12:52 AM
djmarch
Aug 10, 2015 08:42 AM
hokis
Aug 9, 2015 03:57 PM
