New Setup Help
Old Jan 26, 2009 | 01:08 PM
85birdy's Avatar
Car: 1985 Trans Am 305 TPI
New Setup Help
Hi, ok fist off, I have a 305 TPI and have some plans i just want your opinions and recomendations please. my engine is bone stock. This spring i want to get some Trick Flow 56cc chamber heads part# 30300005 along with 1.6 rollers. I heard these heads are probably the best for a 305 right now, along with Edelbrock High flow base plate, SLP runners, port matched plenum, coolant bypass lol, custom K&N cold intake and Hooker shorty's. If i got those things done, would i need to get some bigger injectors? and also what would you guys pick as a Cam to go along with those heads? not extremely wild but a descent cam for street/strip application and that will profit from these heads
also I do 15.4 at 89mph, well i am bone stock, what would you guys think i would be close to if i had all this good stuff?
Old Jan 26, 2009 | 01:50 PM
ChoobinatoR's Avatar
Re: New Setup Help
why not start with a 350?
Old Jan 26, 2009 | 03:17 PM
85birdy's Avatar
Re: New Setup Help
Simply Because i want to make a 305 go fast. everyone does the 350 i want to mix it up
Old Jan 27, 2009 | 09:54 PM
85birdy's Avatar
Re: New Setup Help
I just read in a small block chevy engine book that the stock 19# injectors from the 305 are good till 350HP with proper tuning (PROM)?
maybe increase fuel rail pressure?
my other concern is that I was planning on keeping the stock internals and rings and just getting TF Heads i mentioned along with cam and edelbrock base, SLP runners, ported plenum and headers. My stock pistons should hold up? what do you guys think about the Rings?
Old Jan 27, 2009 | 10:20 PM
86camaroZ's Avatar
Car: 86 iroc
Engine: 350 vortec HSR
Axle/Gears: 370
Re: New Setup Help
injectors should be more then good.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
LT1Formula
Oct 8, 2015 08:34 PM
meeklay812
Oct 1, 2015 03:46 PM
dusterbd
Sep 29, 2015 08:40 AM
Badass355ciz28
Sep 28, 2015 08:31 PM
