Taking off the Fuel Rail sure is FUN ! PIC INSIDE
Old Mar 2, 2009 | 05:33 PM
ausi gto's Avatar
Car: 1991 Trans Am vert
I have 3 bad injectors so I took off the rail tonight.
The bolt that holds the fuel lines on at the front of the block is really fun to get at !!! (it was easier to remove the water neck)
I was able to remove the EGR and and get the Rail out without removing the intake runner on the pass side !
I'm installing 8 new 19lb Ford injectors !
* Yes, I know it needs cleaning....but, Hell, I just bought it last Monday and it broke 4 days later !
Old Mar 2, 2009 | 10:00 PM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Taking off the Fuel Rail sure is FUN ! PIC INSIDE
Since you essentially got the top end apart, remove the other runner.
It only takes a few minutes to put everything back together if you know
the sequence of events. I say, invest in a few cans of aluminum paint.
If it were me and the car wasnt my daily driver, id spend a weekend
cleaning it up! Id rip the intake, water pump off, the belt tensioner and
paint the intake, belt tensioner, pulleys and the water neck. The alternator
is rather funky as it is, id just let it burn up!
and, if I had a spare hundred some odd bucks, id get some tall deck
chrome valve covers while your at it! After you done, the car will unrecognizable
to the original owner i bet!
anyway, enough of my mouth!
Get to work!
Old Mar 2, 2009 | 11:47 PM
ModPog84z28's Avatar
Car: 1989 Camaro RS
Engine: 496 BBC
Transmission: T-56 6 speed
Axle/Gears: 4.11 posi
^^ agreed ^^ some extra time, elbow grease and paint could make that a gem. hell just remove the acc. mounts and paint that too. the tall deck valve covers are a good thought too. especially if you get some aluminum ones, theyll help keep the oil on the valvetrain cool as well (plus you can nab some roller rockers online and then your set ) good luck, doing the tune up shtuff on mine tomorrow as well!
Old Mar 2, 2009 | 11:48 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Ah, been there man. I suggest next time you take the knock sensor out from under block long enough to drain more coolant so you don't get green crap dripping everywhere.
Old Mar 3, 2009 | 12:13 AM
Car: 1989 Camaro RS
Engine: 496 BBC
yea, or unhook the lower water pump hose, either works, and ive done the same thing as him, learned the hard way...:P
Old Mar 3, 2009 | 04:41 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Don't paint the intake. Media blast it. Looks cleaner and you don't have to worry about carb cleaner messing up the paint.
Old Mar 3, 2009 | 05:51 AM
TPI's Avatar
Yea, and flaking is always a nuisance!
Old Mar 3, 2009 | 06:52 AM
Slowridr's Avatar
Car: 1987 GTA Vert & 1991 GTA 5 Speed
Engine: 87 GTA-L98 91 GTA LB9
Transmission: GTA-700R4 & GTA T5
When you put that thing back together could you get a pic of where your Manifold Air Temp Sensor MAT or sometimes called Idle Air Temp IAT sensor hooks into the harness. Ive been trying to find this forever cant seem to find it. Heres a pic of mine and the wire coming off of it.
and
Good luck with the rest of the fuel injector changeoever
Old Mar 3, 2009 | 10:59 AM
ausi gto's Avatar
Thanks everyone, but yea, its a daily driver . So once I get it all back together and running well, then I'll clean it up.........I'd like to drive it with the top down for more than 4 days.........lol
Old Mar 3, 2009 | 05:24 PM
ausi gto's Avatar
Mines about 18" long and comes off the back of the upper plenum and it heads over towards the brake booster.
Its not 'in' any harness, it runs all by its self !
Old Mar 3, 2009 | 05:26 PM
ausi gto's Avatar
I put the new Ford injectors in and pressurized the fuel system 'before' the upper plenum and no leaks at all.........I wanted to make sure since I've heard about a few people having these leak.
Old Mar 3, 2009 | 10:13 PM
TPI's Avatar
Thanks everyone, but yea, its a daily driver.
Yea scratch the paint project! I remember one weekend I was doing
alittle mod to my car, BUT had to drive to work on that Monday...
Long story short, It didnt get done and I had to bum a ride!! HAHA!
Old Mar 4, 2009 | 04:42 PM
ausi gto's Avatar
Well I'm all finished - and 'wow', does this thing idle smooth !
I am amazed at the difference in the idle quality and throttle response.
For people that have the stock style injectors, I did nothing except change them to the Ford 19lb 'yellow top' style and what a difference.
Well worth the work I spent on it.
Old Mar 4, 2009 | 06:05 PM
TIMMYS89GTA's Avatar
Car: 81z-28,89gta,91z-28 03 1500
Engine: 355,L98vette tpi,327
Transmission: TH350/700R4/700r4/4l80E
Axle/Gears: 3;73/3;27/2;73/3;73
YES SIR!
I also agree that stock multec injectors are junk!
Old Mar 4, 2009 | 08:43 PM
TPI's Avatar
Glad she is back on par, clean her up next time around!
Frozer!!!
Jan 19, 2024 04:55 PM
Andrew6.688
Dec 13, 2015 10:59 AM
92camaroJoe
Aug 13, 2015 06:07 AM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
