Too Much Gas
Old Apr 3, 2009 | 12:30 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Too Much Gas
My mechanic did some work on my car yesterday, when he turned it on he said my engine was getting too much gas. Is this bad, if yes how can I fix this?
Old Apr 3, 2009 | 02:09 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: Too Much Gas
any codes?
Old Apr 3, 2009 | 04:15 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Too Much Gas
My SES light is on but haven't check for what code it is.
Old Apr 3, 2009 | 06:24 PM
Car: 91 Trans Am
Engine: 355 TPI
Re: Too Much Gas
i had code 33 which is MAF Circut high, that would cause a rich condition because the computer thinks more air so it needs more fuel, which it doesn't but it thinks it does....check your codes using the jumper wire method and look for code 33, if you have code 34 check the MAF relays
Old Apr 3, 2009 | 06:42 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Too Much Gas
It gave me 4 codes! Code 34,36,44, and 54.
Old Apr 3, 2009 | 08:08 PM
Car: 91 Trans Am
Engine: 355 TPI
Re: Too Much Gas
should have given you 12 to tell you ECM is working properly
34 - Maf gm/sec low (check MAF power relay)
36- MAF burnoff (check MAF burnoff relay)
44- O2 sensor lean, possibly caused by MAF codes
54- i don't know what that code is
i hope this helps
Old Apr 3, 2009 | 09:13 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: Too Much Gas
Didn't your mechanic pull codes
that should be the first thing he should have done.
Old Apr 3, 2009 | 10:07 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Too Much Gas
No his dumb*** didn't. I figured out that some of my relays weren't hooked up after he did the swap on my car. I plugged em in but I still get a SES light. I'm going to check for codes again tomorrow.
Old Apr 4, 2009 | 01:21 PM
Car: 91 Trans Am
Engine: 355 TPI
Re: Too Much Gas
reset the computer by unhooking the negative battery cable for a few minutes, and then start the car up and let it run till you get a check engine light and then re check the codes. once a code pops up it gets stored until the computer is clear, so all 4 codes may not be the current problem. so reset it and re-check it and go from there
Old Apr 4, 2009 | 05:19 PM
Iroc_87's Avatar
Car: 1987 Iroc-Z28
Re: Too Much Gas
I got rid of two codes but I'm still getting code 33 and 36.
Old Apr 5, 2009 | 01:09 PM
Car: 91 Trans Am
Engine: 355 TPI
Re: Too Much Gas
33 is probably your MAF sensor i would check the wiring first , 36 is the burnoff circut, check the relay
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
KCG
Jun 24, 2020 04:33 AM
86maro_252
Oct 10, 2015 06:52 PM
kx3g
Sep 28, 2015 08:14 AM
reactor60
Sep 22, 2015 01:44 PM
