how big can i go with my cam?
Old Apr 25, 2009 | 11:30 PM
GIJason91's Avatar
Car: 1991 Camaro RS
Engine: 5.7 350 TBI
Transmission: M5
i have a 87 camaro irocZ28 5.7L TPI. currently i have a mild edlebrock torqer cam(not sure what size it is) and stock tpi. i also have world product sportsman 2 heads with the 72cc chambers WRL-012250-2. soon ill be looking at getting a new holley stealth ram and a twin cold air intake so i can grab a higher power band. I'm looking for a really lopey cam to go with my set up can anyone reccomend a good combonation to go with the holley stealthram and the sportsman 2 heads?
Old Apr 26, 2009 | 08:01 AM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: how big can i go with my cam?
If that's a stock engine, 72cc heads will hurt your compression. Why would you put an Edelbrock flat tappet cam in a roller blocK???
As far as the famous "which cam" question, do a quick search... cams have been talked about extensively.
Old Apr 26, 2009 | 08:36 AM
GIJason91's Avatar
Car: 1991 Camaro RS
Engine: 5.7 350 TBI
Transmission: M5
its an older block passed down through some generations so the heads were bad i had those laying around and my brother had put the cam in a few years back, i dont think this block was ever a roller block.
Jorlain
Oct 8, 2015 01:57 AM
Nick McCardle
Sep 10, 2015 08:36 PM
BOOT77
Sep 5, 2015 03:55 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
