quick tpi question
quick tpi question
i heard that the 350 tpi had a intake problem im not sure on what it was im just trying to find out what it is and how i can avoid it can anyone tell me any and all potential problems and how i can aviod runing into those problems.
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
Re: quick tpi question
if you take it apart its kind of a pain to seal it good. thats the only prob i know of besides aparently falling on itss face past i believe 5800rpm maybe lower not 100%
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Falls on it's face ~4800 rpm.
The "problem" is that the tpi was designed for the 305 and not the 350.
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
Replacing the runners with something by slp or edelbrock will help that problem. The base can be replaced with something better flowing from edelbrock or accel.
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
First it would help a lot if you could state your goals for this car. The goals help you decide what type of system to use.
My goals were a bruser from stop light to stop light and at home on a highway cruise without having to stop more often for gas than to take a leak. That's exactly what my TPI does for me. Sometimes I wake up and can't back to sleep so I pull the tops of and go for ride on the freeway, man do I love this car!!
Car: 1994 Trans Am
I was always confused by the "TPI was made for the 305" comment. The Vette has always had the L98, never the Lb9. So why would they design a motor for the Fbody and put it in the vette. Seems to me, it was the other way around. They designed the L98 and gave the Fbody the baby version.
I know the history, but It just seems backwards.
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
Axle/Gears: 3.08 Posi
theyve screwed up a few times (350/t5 issue etc) but thats why the aftermarket part industry exists, it wouldnt be fun building cars if they did it right the first time lol
moral of the story is they slapped the same system on both motors, and decided it was good enough, the Vette is obviously GM's prize car, always had been so they paid more attention to it and made it work. Just get a new intake and runners, make it flow and call it a day
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
The TPI was made for the 305
.... just wanted to add, as I'm sure you guys remember this TPI comparison. They purposely used a 383 small block chevy, TFS aluminum heads, and comp XR288HR camshaft, to show the benefits of the "more expensive" setups. Had they used a 350 small block or smaller, with STOCK heads, the other setups wouldn't have made that much of a difference in comparison, nor justify their cost.
http://www.compcams.com/Community/Ar...?ID=1737510521
thanks for all the in put it.
rgarcia63 First it would help a lot if you could state your goals for this car. The goals help you decide what type of system to use.
i want a camaro that i can drive. but i want performance as well. easyeir to say i dont want a track car. but i want to drive the car i have a nice house in the hamptons and the drive would be great. but i would like it if i dont have to fill up till have get there and relax a bit not 2 times before i get there. but also i am a kid and me and my friends like to go to car shows so it would be a bit of a show car and if needs be show off car if you know what i mean. nothing to crazy but somehting a little special.
Sanjay
Aug 12, 2015 03:41 PM
