More power
Old Jun 5, 2009 | 02:39 AM
camaronut396's Avatar
Car: 1989 Iroc-z Camaro
Engine: Procharged 383 Holley Stealth Ram
Transmission: Soon to be ATI TH400/Borg Warner t5
Axle/Gears: Moser M9 4.86
More power
So i just went to the track and found out what i ran. I ran the best of a 14.3 at 96 mph, with the following done to my camaro, which isnt much. Put in a bone stock 91 350 tpi, becool radiator, and 3.73 gears.. not much. But now i wanna do some work and get in the low 12s or high 11s.
What does everyone think i should do next, to go even faster, which everyone wants to do. I cant decide to either, turbo or supercharger my 350, or buy some heads, or have my stock heads ported and polished. Or build a stroker motor. I also want to keep my car fuel injected, but have heard that tpi's lack power. So then should i switch intake systems? Let me know what everyone thinks i should do. Need some advice from people who have done it. Thanks!!
Old Jun 5, 2009 | 01:06 PM
navyCM's Avatar
Car: 87 IROC
Engine: 5.7 TPI
Re: More power
lack power they do not lack. tons of torque in a TPI, HP is where it lacks at high RPMs, over 5500. depends on your budget its going to cost a good bit to get it in the 11-12s, id say youd need over 500 HP to get it there. can be done though.
Old Jun 5, 2009 | 02:02 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Re: More power
There are a lot of options you mention in your post. You should start by doing some searches. Also keep an eye on what everyone else is running in their signatures and their respective run times.
83 Crossfire TA
Jan 3, 2016 01:26 PM
my86bird
Oct 23, 2015 12:20 PM
Gunsbee
Sep 7, 2015 07:10 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
