Engine Balancing question
Old Jun 12, 2009 | 04:58 PM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
I recently purchased a 383 rotating assembly for my engine. It says its internally balanced so I would need a neutral balancer and I'm guessing neutral flexplate. I swapped out my auto for a t56 transmission. Are the LT1 flywheels neutrally balanced and will the stock balancer work or do I need to order a new balancer? How can I tell if the flywheel is external or neutrally balanced? When I installed the transmission when the original crank was in the car, it had a small counterweight on the crank and the lt1 flywheel had a hole that fit right on that counterweight.
Old Jun 12, 2009 | 06:18 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Engine Balancing question
Is it a balanced kit? 1 piece or 2 piece RMS?
Old Jun 12, 2009 | 06:27 PM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
It is not a balanced kit. I called scat and they said it was neutral in the front and external in the rear. Its a 1 RMS. The thing is summit advertises that it's internal balanced and scat sight says BIE. Can it be balanced both ways?
Old Jun 13, 2009 | 04:12 AM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
Anyone else have any info to the post? Again is the stock balancer neutral or do I need a new one? I looked at the back of the flywheel and it has burrows where is looks like it was balanced on the lt1 engine.
Old Jun 13, 2009 | 05:14 AM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
what kit are you using, i recently got one of their kits and went and had it balanced
Old Jun 13, 2009 | 06:20 AM
Kodfish's Avatar
Car: 1990 IROC
Engine: 5.7 TPI
I have the 1-41755; 383 forged crank, forged rods, forged aluminum dish pistons, 9.8cr with 64cc heads.
Did you have to use your stock balancer or get a new on that was neutral?
Old Jun 13, 2009 | 03:14 PM
i bought a neutral flexplate and balancer and had it balanced at a machine shop
italiano67
Dec 11, 2016 09:21 AM
InfinityShade
Aug 22, 2015 08:00 PM
redmaroz
Aug 16, 2015 11:40 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
cRoe4
Aug 7, 2015 08:46 PM
