MY DYNO RUN
Old Jun 15, 2009 | 10:16 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
MY DYNO RUN
http://www.youtube.com/watch?v=qiXkNUFMIMg
This was done on a Dyno Dynamics machine
http://www.dyno.com.au/dyno/controller
I hear they put out numbers close to a Mustang Dyno.
I thought it would peak a bit higher rpm and TQ peak would be lower....
As you can see its running very lean.
Maybe too lean?
But at idle it seems to run rich--the smell and the black inside of my tail pipes.
I only get 20mpg on the highway too.
Comments are welcome
Old Jun 15, 2009 | 10:18 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: MY DYNO RUN
"I hear they put out numbers close to a Mustang Dyno."
Most are lower unless they have had the calibration changed.
Old Jun 15, 2009 | 10:31 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: MY DYNO RUN
Maybe too lean?
Overall not bad at all and it sounds pretty healthy. It just needs some tweaking.
WOT is too lean. Personally I would like to see it down in the 12.5:1 afr range if it were my engine on our modern gasoline. Never know when you are going to find a tank of E10.
The torque numbers are likely being skewed by your converter. Alse your build looks to be fairly overcammed for the top-end of your engine to support. What I am saying is you could have made the same power with a smaller cam.
Here is a rather extreme case of torque skew from a loose converter coupled with Wide Open Throttle Force Lockup @ 80-85 mph. Stock S10 4.3 V6 converter behind a L31 Vortec 350 in a fullsize G1500 conversion van. Peak torque should have happened at 2,800 rpm and peak hp at 4,600. The only modifications were a S10 converter, DIY PCM Reflash/87 octane TUNE, and a Transgo HD2 shift kit.
Old Jun 15, 2009 | 11:12 PM
avro206's Avatar
Car: 89 Formula
Re: MY DYNO RUN
do mean the rpm peak or the number itself?
Also your build looks to be fairly overcammed for the top-end of your engine to support. What I am saying is you could have made the same power with a smaller cam.
I hear you on the cam. It was just built that way---I would like a better intake. Peaking at 4400rpm sucks.
Yeah a think I might get a better chip for it---and an intake
Old Jun 16, 2009 | 11:00 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
Re: MY DYNO RUN
I mean the rpm peak would have occured at a lower rpm with a tighter or locked converter.
The cam is not a terrible mis-match, but is limited by the intake. Is this a stock chip running on the MAF setup?
Old Jun 16, 2009 | 11:30 PM
avro206's Avatar
Car: 89 Formula
Re: MY DYNO RUN
not a stock chip--still MAF. Previous owner did all the mods.
MustangBeater20
Oct 29, 2022 09:20 PM
Kevin91Z
Southern California Area
22
Sep 19, 2022 10:00 AM
1984HO
Mar 19, 2021 11:59 AM
Fast355
Dec 2, 2016 06:33 PM
85Iroc-Z
Aug 13, 2015 01:58 AM
