TPI Dyno Tuning
TPI Dyno Tuning
what's up guys, I am building an engine to push about 450 hp. I live in New jersey. is there a place in this general area or a few states over that can do a dyno tune. Thanks in advance!
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Re: TPI Dyno Tuning
Could you please post your build specs on this engine?
Re: TPI Dyno Tuning
There is a guy by me in dover, nj but to make a long story short he came across to my friend and I a scum bag and after dynoing a customers brand new Z06 did several burnouts in the middle of a state highway and wrecked the car.
Car: 1986 IROC
Engine: 355" TPI
Re: TPI Dyno Tuning
I never found a place that did it when I was in jersey. Im having the same problem in georgia now. So I ordered the crap to do it myself. Hopefully It not too difficult.
Re: TPI Dyno Tuning
there has to be someone who tunes these cars. There are plenty of guys with mods here and i'm sure someone has gotten their car tuned somewhere. I've called cartek and vette doctors and they both said they don't mess with our stuff. They said it's too much hassle.
I don't get it. If i would have known this i would have gone with a carb setup.
I don't get it. If i would have known this i would have gone with a carb setup. Trending Topics
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: TPI Dyno Tuning
Just get the stuff to tune yourself. YOU do the tuning while the car is at the dyno. That's how I had to do it. No one around me plays with these cars anymore either.
Car: 1986 IROC
Engine: 355" TPI
Re: TPI Dyno Tuning
I dont think tuning was ever common back when the cars were newish. The maf cars were tollerant to most mild changes and people belived a fuel pressure regulator could make it work.
Re: TPI Dyno Tuning
thanks, but i don't want to do it myself. I have no idea about tinkering with that stuff and would prefer professional help. Too much involved for me. I just want the car to run right. It hesitates and surges and the throttle response is way off.
Engine: 5.0 TPI
Transmission: TH700R4
Axle/Gears: 3.43 posi
Re: TPI Dyno Tuning
don't know for sure if this place does dyno tuning but they are very active on my local f-body forum http://jsspeedandcustom.com/ very close to philly, i'm not sure where in jersey you're located
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: TPI Dyno Tuning
whats your engine combo and is it MAF or SD? MAF cars are pretty easy to tune, while SD is a touch harder but still doable. MAF can tolerate mods better than SD so you can get the tune pretty rough and still run on MAF, while SD may not run.
Moates.net has all the stuff you need. If you were out this way, (pittsburgh area) i could help tune your car
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Sanjay
Aug 12, 2015 03:41 PM
