TPI fuel rail
Old Jul 13, 2009 | 12:45 PM
wjr's Avatar
wjr
TPI fuel rail
whats the process of pulling the 2 fuel rails out?Everything else is off down to the rails.Do they seperate from the rail or intake or do i have to seperate the rails,because of the angle of the injectors? Just need some advice Thanks in advance
Old Jul 13, 2009 | 05:03 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Re: TPI fuel rail
4 bolts hold the rails down, and the 2 fuel lines are connected at the front of the block, drivers side. once you have the rails unbolted and the fuel lines disconnected, you might have to pry them up a bit but they will release from the manifold. if they are factory they have clips retaining them at the rail, and they will move enough that you can pull the entire assembly without dismantling the 2 sides
Old Jul 15, 2009 | 11:35 AM
wjr's Avatar
wjr
Re: TPI fuel rail
got it Thanks and the motor is out apprciate the help
Andrew6.688
Dec 13, 2015 10:59 AM
Brcharrelson
Aug 26, 2015 07:47 PM
Sanjay
Aug 12, 2015 03:41 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
92projectcamaro
Aug 6, 2015 01:20 PM
