IAC COUNTS ?
Old Jul 21, 2009 | 09:13 AM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
IAC COUNTS ?
What should the IAC counts be for a heavily modified 383 TPI?
I know Ed Wright says below 100 is good, but 1-100 is alot of room to set at.
Old Jul 21, 2009 | 07:28 PM
Car: 1988 IROC-Z28
Re: IAC COUNTS ?
I got a hold of Ed Wright,
and he said 20-30 in case anyone was interested.
Old Jul 21, 2009 | 11:45 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Re: IAC COUNTS ?
After my H/C/I swap, I had trouble with a low idle in gear. My IAC was maxed out. I adjusted the throttle screw, and got my IAC counts to 80 (It was at 80 before the swap). Idles like a champ in gear now.
Old Jul 22, 2009 | 10:12 AM
Car: 1988 IROC-Z28
Re: IAC COUNTS ?
So your saying that your IAC is at 80 now! If so that would make sense. Cause I can't get mine to come down to 20-30. With all the changes I've made to my IROC.
Anyone else have this issue, and what did you set yours at?
Old Jul 22, 2009 | 10:55 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: IAC COUNTS ?
It depends on several factors:
*Where you want your minimum air rate set (throttle blade)
*How big your TB is
*What your idle speed is
*How much your PCV is flowing
*If you have any bypass holes in your TB
*Your engine size and VE at idle
*What air-fuel ratio you want at idle
*If you're getting EGR flow at idle
*If your exhaust scavenges at idle
*Your manifold air pressure at idle
Old Jul 22, 2009 | 12:03 PM
Car: 1988 IROC-Z28
Re: IAC COUNTS ?
I don't have a PCV any more, just a breather on each valve cover.
Old Jul 22, 2009 | 02:41 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: IAC COUNTS ?
Why no pcv, it's a good thing
Old Jul 22, 2009 | 08:30 PM
Car: 1988 IROC-Z28
Re: IAC COUNTS ?
didn't think I need it since I removed all emissions due to a complete rebuild. The car is pretty much a show/cruise car now. I only take it out the weekends. What are the benefits to putting one back on now?
Old Jul 23, 2009 | 10:18 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: IAC COUNTS ?
It keeps the oil cleaner by removing fuel (solvent) and water (corrosive) vapor from the engine. I don't like the extra oil going into my intake so I always run a fuel-filter between my PCV valve and the manifold.
Venting only does allow vapor to escape, but PCV does a better job of it.
Old Jul 23, 2009 | 04:48 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: IAC COUNTS ?
I have my heavily modified 383 at 10 IAC counts at hot idle park.
Old Jul 23, 2009 | 09:36 PM
Car: 1988 IROC-Z28
Re: IAC COUNTS ?
How is that possible?
After I've done some homework stock is 20-30, with a heavily modifed engine, it should be higher!
Old Jul 24, 2009 | 04:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: IAC COUNTS ?
In the DIY Prom forums, they suggest 8 - 10 counts. This gives you nearly the full range of the IAC for that extra air at WOT.
Getting the count of 10 was the easy part. Massaging the fuel and spark to give me a non-surging idle was the difficult part.
Old Jul 24, 2009 | 07:50 AM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
Re: IAC COUNTS ?
You can have your IAC count be whatever you want it to be. Read my first post again.
If you're not tuning via calibration changes to your ECM, then that's probably your problem. You said you were trying to get your IAC counts to come down, but you didn't say how. It seems like a question to post on the DIYPROM section.
Either that, or you haven't yet clearly stated your problem.
db057
Jan 10, 2020 08:55 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
greenyone
Sep 2, 2015 03:39 PM
