cleaning injectors can it be done?
Old Aug 7, 2009 | 06:34 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Axle/Gears: 373 zexel torsen
I found my injectors stopped up with varnish. The car had been setting for 4 yrs.I had 43 lbs to the rail, put light on injector harness and it blinked as the starter turned over, ok I pulled the injectors out put 12 volts to each one as I sprayed car cleaner thru them then sprayed air thru them as they were held open with the 12 volts. Will this work for cleaning them?
Old Aug 7, 2009 | 11:36 PM
Chevy86 IROC-Z's Avatar
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Re: cleaning injectors can it be done?
I did the same buddy. I pulled them out, connected a little nine volt battery, and sprayed just a little. I really dont know if its good or not because yes gasoline is harsh on some rubbers and plastics, but as we all know, carb cleaner is a very powerful cleaner and it can destroy rubber. My point is, I dont know if it (carb clearner) is to "acidic" for the little rubber pieces at the tips of the injectors. It did clean out the injectors, but as soon as I get my engine running, Im going to dump a fuel injector cleaner, fill up with supreme unleaded and dump octane booster. Then hit the drag strip, just to clean the sh*t out of the fuel system. I highly suggest your have the injectors serviced at a shop that performs ultrasonic cleaning techniques. Check out this video to see what Im talking about............. http://www.youtube.com/watch?v=ZJmdvoZ83hY
Old Aug 8, 2009 | 11:39 AM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
I have not found a shop to clean them around here maybe I can get them clean enough to get this car moved. Thanks
Old Aug 8, 2009 | 02:16 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
www.cruzinperformance.com
Old Aug 8, 2009 | 02:54 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Give some of these a try. I did make my own years ago with an extra set of fuel rails ,extermal fuel pump, etc.
http://fordfuelinjection.com/?p=82
http://www.cosworthvega.com/Articles...%20Cleaner.htm
http://specthismiata.com/2008/06/15/...aning-at-home/
Old Aug 8, 2009 | 03:44 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks TPI I will try your way of cleaning them money is on a tight budget just to move a car. If I decide to keep the tpi I will invest in some injectors later when economy gets better, and that could be a while Thanks again
Old Aug 8, 2009 | 04:50 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I have some Stock LT1 24lb injectors Id sale for $75shipped. Work fine as they are in the car now. But I need to get off my a!@ and put my 50lb ers in.
Old Aug 8, 2009 | 08:50 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Do you know if they would work in a stock 305?
Old Aug 8, 2009 | 09:40 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
you will be running rich... 305 comes stock with 19s. might be a bit much
Old Aug 8, 2009 | 09:54 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Thanks Thunder didn,t know that. I am new to this tpi stuff, makes a carb sound better every weekend I work on it. But I would like to get it running to see if I want to keep it original.
Old Aug 8, 2009 | 10:16 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
would be a tad rich. Is the car all stock? nothing a tune wouldnt cure.
Old Aug 9, 2009 | 09:23 AM
southbay08's Avatar
fuel injector cleaners only work to a certain degree, it will not be able clean any carbon buildup that may be stuck on the inside of the injector. If at any point you decide that you would like them professionally cleaned...we posted a 10% off sale on all of our fuel injectors and clean/flowtest services.
if you are interested go to our website and type in code TG11 at checkout.
www.southbayfuelinjectors.com
Old Aug 9, 2009 | 03:31 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Yes TPI all stock and original I really just want to get it cranked up had it since May beginning to wonder if all this work is worth fooling with.
Old Aug 15, 2009 | 09:58 PM
Dustytrix's Avatar
Car: 1990 Iroc
Engine: 6.0
Transmission: 4l65E
Just a follow up I used TPI,s advice on cleaning and got my car cranked for 1st time in 4yrs.Running a little rough but its running.
Old Aug 15, 2009 | 11:16 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
Glad it worked out for ya.
Old Sep 15, 2009 | 07:01 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Does anybody know if GM lt1 injectors have serviceable filters?
Old Sep 15, 2009 | 07:47 AM
southbay08's Avatar
if your filters are dirty, just pop them out and replace them
Old Sep 15, 2009 | 08:10 AM
Toehead's Avatar
Thanks for the reply. I scored a set of two lt1 fuel rails with injectors for 50 bucks. I havn't seen them yet, but they were running pulls and I am going to replace my stock injectors this winter when I do the valve stem seals.
How do you recommend I check? Do you sell the replacement filters?
Thanks!
Old Sep 15, 2009 | 10:16 AM
southbay08's Avatar
we sell the filters, but we will just send you a set if you decide to change them out. Just PM us with your address, but Just know that changing the screens is not the answer to a "clean" injector.
Old Sep 15, 2009 | 05:42 PM
Toehead's Avatar
Wow, that's really nice of you!
I realize this.. I know that I really should have them ultrasonically cleaned while being pulsed, but I just moved out on my own and am on a killer budget...
How much do you charge per injector? I'll have a spare set, so maybe i'll send you a set to work over with my tax rebate!
Old Sep 15, 2009 | 05:54 PM
southbay08's Avatar
I hear ya! We charge $15 per injector for the clean and flowtest service, but again if you just want the screens for now we will send them to you no charge.
Old Sep 16, 2009 | 04:49 PM
Toehead's Avatar
You have a PM!
Old Sep 17, 2009 | 03:15 AM
TXFBODYGUY's Avatar
Car: 1986 I-ROC
Engine: TPI 305
Transmission: STOCK
Axle/Gears: STOCK
i had this same problem as my car had sat since 95 all i had to do was a new fuel pump and 2 16oz cans of b-12 in the tank and let it run and they cleaned right up
specialized
Jun 18, 2022 09:26 AM
Street Lethal
Apr 30, 2019 12:14 PM
69 Six Pack
Oct 5, 2015 07:51 PM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
