are the injector clips necessary?
Old Aug 8, 2009 | 04:23 AM
matthufham's Avatar
Car: 90 z28
Engine: 355 with hsr
Transmission: t56
Axle/Gears: 3.73 posi
switching from stockers to some mustang ones i broke 3 of the clips while installing them. i heard the clips can be avoided, that bolting the rails in will do the job just fine. so if you could confirm or argue this i'd appreciate it. and where are these clips available to buy?
Old Aug 8, 2009 | 05:22 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: are the injector clips necessary?
They can be bought from GM.
Do you really want to chance not putting on the clips when they're less than 10 bucks form GM?
Old Aug 8, 2009 | 05:59 AM
megtom2's Avatar
Car: 1989 Pontiac Formula 350
Engine: 350 tpi
Transmission: 700
If they have the slot I would say put them in. I just installed the type III injectors and they don't use them. Incredible improvement.
Old Aug 8, 2009 | 07:46 AM
renemedrano842's Avatar
Car: 92 GTA
Transmission: 5 Speed
Axle/Gears: 3.27 posi
when i installed my mini ram the fuel rails did not have the provisions for the clip and i have seen no problems with it so far. i dont think you need them as long as you have good o-rings and the fuel rail is mounted tight.
Old Aug 8, 2009 | 08:01 AM
southbay08's Avatar
The design lll are a newer design, the pressure from the fuel rail is what holds them in place
Old Aug 8, 2009 | 10:11 AM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
You don't need them. Just make sure you seat the injectors in the rail first, then seat the whole rail into the manifold.
Old Aug 8, 2009 | 10:18 AM
southbay08's Avatar
actually they should be installed into the intake manifold first and then into the rail so they will seat properly.
Old Aug 8, 2009 | 10:25 AM
All I know, is the first time I installed injectors years ago, I did that and the injectors did not seat in the rail right, and sprayed fuel everywhere. I had to take it all apart again.
It is WAY easier to install them in the rail first, then tap the rail in firmly with a rubber mallet. Then install screws. I have done it this way many times, and I have had no problems.
If you were going to use the factory clips, how on earth would you install the injectors into the manifold first? I can pretty much guarantee, that the at the factory, they installed the rail with all of the injectors already in place.
Old Aug 8, 2009 | 11:02 AM
southbay08's Avatar
you do not use factory clips on the design lll's they were squirting fuel all over because it is a known fact that they are 1/8 to 1/4 shorter than stock if the injector has an additional spacer or ring on it, they will not leak, i never heard of hitting a fuel rail with a mallet!
Old Aug 8, 2009 | 11:09 AM
They were stock, original injectors.
Old Aug 8, 2009 | 02:57 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
I never use em. TPI or LT1 Ive done. Ford or GM or Aftermarket injectors.
You have bolts holding the fuel rails down, what do you think a injector is gonna just fall out?
Old Aug 10, 2009 | 01:04 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Don't need them, but if you want to install them, it's not a bad idea. Especially if you have to remove the rail a few times for odd things. Also, you can use some silicon spray to lube them and be easier to work with without pinching or tearing any o-rings.
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
jerflash
Sep 24, 2015 03:11 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
