Where am I leaking oil from???
Old Aug 8, 2009 | 10:17 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
The leak is located above the bell housing, and I just redid the manifold gasket only to find that isn't the leak... It is leaking pretty bad too.
It isn't the distributor or the valve covers either... Is there some sort of oil ports on the back of my block above the bell housing?
And yes, I have tried to wipe it all down and see where it is leaking from, but the bell housing is in my way, and I can't see from the top either.
Old Aug 8, 2009 | 10:24 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
Transmission: 700 R4
Re: Where am I leaking oil from???
your oil pressure sensor should be back there
Old Aug 8, 2009 | 10:43 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That is a possibility, I mean it is leaking pretty bad though. Like a 5" puddle after parking.
It runs down from where it is leaking, to a big wiring loom, from there, it runs and drips onto the bell housing on the driver side, it then runs down the bell housing to makes a mess under my car and on the ground.
Old Aug 8, 2009 | 10:53 PM
teamstream's Avatar
Car: 91 Purple Z28
Engine: 5.7 TPI
well....could be a start...does it leak bad if its running and sittin still?
Old Aug 8, 2009 | 11:13 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
Pictures might help. Your description was kinda confusing for me. But if its leaking a lot out the back of the block, id say rear main seal.
above the bell housing, might be oil pressure sender, maybe it leaks around the oil filter? might be your intake manifold or valve covers or distributer.
Other then that, maybe a hole in yer block? lol Only plugs in the back are for coolant if im not mistaken.
Old Aug 8, 2009 | 11:42 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
a little bit of oil looks like alot more when it hits the ground and spreads out and how bout the back of the intake
Old Aug 9, 2009 | 01:51 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Back of the intake is dry. I just did the gaskets and checked them.
Old Aug 9, 2009 | 04:33 PM
SMURFN' Z28's Avatar
Car: 1994 Jeep Wrangler
Sounds like the rear main seal.
Old Aug 9, 2009 | 04:47 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Isn't the rear main seal under the bell housing? I know for a fact that the leak is about the bell housing.
Old Aug 9, 2009 | 06:47 PM
Chevy8588's Avatar
Car: 1987 Iroc Z28/ 1982 Z28
Engine: 355 TPI IP/ 305 CFI
Transmission: T-56/ 300C
Axle/Gears: 3.42 Open/ 3.73 Posi
oil pressure sensor
Old Aug 9, 2009 | 09:57 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
its the oil pressure sender fitting. mine was loose.. leaked like mad. it pools up on the lip the fitting comes out of and runs down the engine/bellhousing onto the ground. take the sender off, you will probably notice the piece it screws into (that screws into the block) is loose. unscrew it, throw some new teflon tape on the threads and screw it back in. you should be good to go.
Old Aug 9, 2009 | 10:06 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That actually sounds like my problem... You can't see the pool of oil though can you? Where is it located? Back of the block on the passenger or driver side?
Old Aug 9, 2009 | 11:03 PM
Chevy8588's Avatar
should be drivers side
Old Aug 10, 2009 | 12:08 AM
thunder85's Avatar
Engine: 5.7L w/hsr
drivers side. your oil sending unit looks like a tin can with a wire plugged into it. follow the line of the head and intake back to the firewall and you will see it. buy another one.. they are cheap as hell and are known to fail. it may be whats leaking.
Old Aug 10, 2009 | 12:16 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
How cheap are we talking here?
Old Aug 10, 2009 | 07:30 AM
thunder85's Avatar
Engine: 5.7L w/hsr
under 20
hit up autozone.com and its part #PS140
Old Mar 19, 2012 | 07:16 AM
OneQwickBird's Avatar
Car: '91 trans am cnvtble and '91 GTA
Engine: 305 and 355
Axle/Gears: stock
I know this is extreme old but they search and then ask questions so anyways, I currently have this same suspicious leak from above the bell housing I'm just wondering if you ever got around to fixing this leak and if you solved it??
Old Mar 19, 2012 | 07:29 AM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I believe it ended up being the oil pressure sending unit. I ended up deleting it and using my Mechanical gauge.
Old Mar 19, 2012 | 10:11 AM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i could be wrong here, but i believe the sensor back there is for the oil gauge and for the ecm. for engine protection?
Old Mar 19, 2012 | 10:17 AM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
yea i wouldnt delete the oil sending unit.... is easy enough to replace..... but mines was leaking badly... i had to put a right angle adapter on there because it would be hard to reach back there and tighten it up and ended up cracking it and had a bad leak that way..
Old Mar 19, 2012 | 04:27 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That is exactly what I had. I think when I rebuilt the engine, I ended up plugging it in the block though. The first time, I just put the plug in the right angle adapter.
Old Mar 19, 2012 | 06:56 PM
Engine: 305 and 355
Axle/Gears: stock
Thanks, especially for the right angle adapter tip. I was already making plans of replacing the rear main seal. I glad I came across this thread! Saved me quite some money not having to pay someone replace it. had been delaying this fix for quite some time now. adding $10 quarts of oil periodically gets annoying and expensive..
Old Mar 19, 2012 | 07:54 PM
luvofjah's Avatar
Car: 91 Black Formula KR
Engine: 305 TPI R69/G92
same leak here, replaced oil sending unit, fixed it too!
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
tgp1990
Sep 4, 2015 06:24 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
