Best injectors
Old Aug 18, 2009 | 06:50 PM
thelast_graham's Avatar
Car: 1984 Chevy K5 Blazer
Engine: SD TPI 350 w/FIC Bosch IIIs
Transmission: 700R4 4X4
Axle/Gears: 3.08 front and rear w/ 33" AT tires
Best injectors
What are the best (effecient, longest lasting, most trusted) injectors I can use for Tune port? Stock L98 with degreed cam, 52mm throttle body and balanced roatating assembly.. So much for your help!! -Andrew
Old Aug 18, 2009 | 07:09 PM
PV9685's Avatar
Car: 89 Firebird Formula
Engine: 305 Vortec, Single-plane, 4 barrel
Transmission: T5, soon 700R4
Axle/Gears: 88 10 Bolt, Disc, Auburn, 3.23
Re: Best injectors
I dunno. I'm sure someone else can tell you though. Are you looking for aftermarket or injectors that are used on production vehicles? Do you know what flowrate you are looking for? stock?
People seem to like the design II and III Bosch units as far as I can tell.
Old Aug 18, 2009 | 07:14 PM
NY87Iroc's Avatar
Car: 1987 Iroc convertible
Axle/Gears: 3.42 posi
Re: Best injectors
+ 1 for the bosch III's
Old Aug 18, 2009 | 07:33 PM
Re: Best injectors
Well... I understand I can run 10% more then stock and ill be fine... I am running LT1 24lbs right now... but I believe the Boschs are better.. I think an injector is plugged up.... cost to clean and have flow matched is what it will cost to buy new ones... so Bosch 3s? Have a part #? Know a great place I can buy them from? Cheap price best quality?
Old Aug 18, 2009 | 07:42 PM
PV9685's Avatar
Re: Best injectors
haha, cheap price and best quality rarely coincide. The best deal would be to pull them yourself at he JY
Old Aug 18, 2009 | 09:02 PM
Re: Best injectors
at he JY?
I have no problem pulling them myself and installing.. I knows how to do this :-) I just need to know what where and price..
Old Aug 18, 2009 | 09:12 PM
american95Tbi's Avatar
Re: Best injectors
Sweet, another K5 guy!
Old Aug 18, 2009 | 10:52 PM
88fastgta's Avatar
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
Re: Best injectors
alot of people use the ford svo 24 pound injectors... i use them too.... great injectors...
Old Aug 19, 2009 | 12:40 AM
Re: Best injectors
I've been trying to find some cheap LS1 injectors
Old Aug 19, 2009 | 12:47 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: Best injectors
The Bosch injectors are good. RC makes good injectors, too. I used them a lot and had no problems, whatsoever. None of these are cheap, but the Bosch are cheaper than the RC's.
Old Sep 2, 2009 | 05:26 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: Best injectors
The Ford 24's are good injectors and cost less than other injectors.
Old Sep 2, 2009 | 11:45 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Best injectors
ford means, and qoute **** over rebuilt dodge. I use venoms, 10% more flow for more 10% more babes in bikini wrestling eachother in mud wanting to ride in your badd a$$ ride. im surprised you havnt blew your diff gears with huge tires
Old Sep 3, 2009 | 06:00 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Best injectors
FYI ford does not make fuel injectors. Bosch makes them for Ford. The only manufacturers of injectors in the world is Bosch, Siemens, Delphi, Denso ans Standard.. There are a few out of china.. Venoms are Bosch cores, ACCell, trick flow, Lucas, are all the same made buy Standard in N carolina. The new chevies all use Bosch, chrysler uses Siemens, Ford uses siemens and Bosch. So stop calling them ford injectors there no such thing.
Old Sep 3, 2009 | 09:17 AM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
Re: Best injectors
I just got some direct replacements from FIC that are Delphi. Havent installed them yet. Has a new style nozzle that is to help create a better spray.
Old Sep 3, 2009 | 06:09 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Re: Best injectors
yea they are good injectors, plus they are exact replacement, so there is no worries
KCG
Jun 24, 2020 04:33 AM
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
webeeZ28
Sep 14, 2015 12:00 PM
