88 IROC problems
Old Aug 24, 2009 | 03:47 PM
88Roc6spd's Avatar
88 IROC problems
Hello everyone. I have a 88 Roc with the L98 TPI and 700R4 auto. I have a few problems with the car such as the temp gauge never works, it rarely moves. Got the code 36 which is causing the hesitation I think. Also, got a huge puff of blue smoke on startup and lasts a few seconds to a minute or so. Fuel tank hums after shutoff and lots of pressure is released when I unscrew the gas cap which stops the humming...anyone have these same problems? Thanks all.
Old Aug 25, 2009 | 04:41 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: 88 IROC problems
1: Check the sensor on the passenger head.
2: Don't have my book'o'codes in front of me.
3: Sounds like your valve seals need replacing.
4: There's a check valve on your gas tank. Replace it or get a breather gas cap.
Old Aug 27, 2009 | 02:05 AM
Twin_Turbo's Avatar
36 is no voltage on terminal D of the maf, usually caused by bad burnoff relay.
Infested
May 22, 2018 11:56 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
mustangman65_79
Aug 11, 2015 03:17 PM
Fronzizzle
Aug 9, 2015 01:15 PM
