pressure?
Old Aug 25, 2009 | 04:23 PM
MTXaudioSYSTM's Avatar
Car: 90 formula
Transmission: auto
pressure?
whats the fuel pressure range for 1990 5.7 tpi?
i have walbro 255 pump and get from 30 -55
Old Aug 25, 2009 | 09:22 PM
Car: 90 formula
Transmission: auto
Re: pressure?
trying to figure out if its my run ability problem. lmk guys!
Old Aug 25, 2009 | 10:41 PM
86T/A_Ram_Air's Avatar
Car: 91 Trans Am
Engine: 355 TPI
Transmission: Built T-5
Re: pressure?
should be around 46 i believe
Old Aug 26, 2009 | 05:08 AM
Car: 90 formula
Transmission: auto
Re: pressure?
all data says 40-48
but what would be up with it going all the way up to 55 and low as 31.
Old Aug 26, 2009 | 07:07 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Re: pressure?
My rule of thumb with FP:
Key on engine off 36PSI
Engine running @idle 36/40PSI
Wot set 42/48 PSI (lower longer pump life)
Shut off after running..FP should go to Zero in about one hour Estimate.
Anything else in my opinion needs looking at......
Old Aug 27, 2009 | 01:05 PM
Car: 90 formula
Transmission: auto
Re: pressure?
thanks. when you turn the key on it puts the pressure about 46ish without running
Old Aug 27, 2009 | 03:27 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Re: pressure?
Sounds good
Old Aug 27, 2009 | 03:35 PM
DJP87Z28's Avatar
Re: pressure?
Originally Posted by 1tpi
Sounds good
Without the engine running and just priming the pump 46 PSI key on seems high.
Old Aug 29, 2009 | 11:32 AM
Car: 90 formula
Transmission: auto
Re: pressure?
thats what i thought. noticed last night its running extremely rich so with that said im ruling out the fuel pump and continuing figuring out whats lacking or going out.
thanks guys with the help!
Old Aug 29, 2009 | 11:52 AM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Axle/Gears: 373
Re: pressure?
Mine goes to 46 with key on primed and runs about 43-45 at idle
and it does not run rich, block learn is 125-132.
db057
Jan 10, 2020 08:55 PM
skinny z
Carburetors
Sep 29, 2015 11:25 PM
Stryker412
Sep 20, 2015 06:59 PM
TBRays98
Sep 6, 2015 05:05 PM
