What kind of Mini Ram do I have?
Subscribe
Sep 11, 2009 | 08:52 PM
Hello,
I have a question about my Mini Ram. I brought it a few years go used.
I am not sure what model is my Mini Ram? I did some search to find out what model Mini Ram I have and trying to see some pictures. But it looks the same and I am not sure where I should be looking at.
What is the different between 1204, 1205 and Fast Burn?
I hope my Mini Ram will work with my 1988 Camaro 350 cid Goodwrench engine.
Any advices would help what model it is?
Here are some pictures of my Mini Ram and thought it would help to determining what model my Ram is.
Thanks, and let me know.
What kind of Mini Ram do I have?-4.jpg   What kind of Mini Ram do I have?-5.jpg   What kind of Mini Ram do I have?-6.jpg
Reply 0
Sep 11, 2009 | 08:54 PM
Re: What kind of Mini Ram do I have?
Here are more photos.
What kind of Mini Ram do I have?-18.jpg   What kind of Mini Ram do I have?-19.jpg
Reply 0
Sep 11, 2009 | 08:57 PM
1204 1205 and Fast Burn are talking about the runner port size.
1204/1205/1206 are felpro gasket sizes, etc..
measure the intake runners and that will tell you the port size. Im not sure if the MR has casting #'s in them or not.
Reply 0
Oct 9, 2009 | 10:36 PM
Thanks, I am not sure what kind of MR it is. But I took a few pictures of the size of the valves.
Hope someone can help me what these MR are from and the model number.
What kind of Mini Ram do I have?-img_2922.jpg   What kind of Mini Ram do I have?-img_2937.jpg   What kind of Mini Ram do I have?-img_2938.jpg
Reply 0
Oct 9, 2009 | 10:37 PM
More pictures.
What kind of Mini Ram do I have?-img_2939.jpg   What kind of Mini Ram do I have?-img_2941.jpg   What kind of Mini Ram do I have?-img_2942.jpg
Reply 0
Oct 10, 2009 | 01:58 AM
Quote: 1204 1205 and Fast Burn are talking about the runner port size.
1204/1205/1206 are felpro gasket sizes, etc...
Fastburn will only have 4 bolt / side
As I recall the later Mini ram II was a air gap type whereas the first model was solid under the plenum?
Reply 0
Oct 10, 2009 | 05:01 AM
im no expert, but it looks like a ram jet crate motor intake.
Reply 0
Oct 10, 2009 | 06:35 AM
Its already determined that its a miniram. I believe hes wanting to know which port size his is. 1204,1205,1206,fastburn. Unfortunately i dont have an answer.Someone should be able to figure it out by looking at the measurements you took of the ports. Good luck
Reply 0
Oct 10, 2009 | 07:24 AM
Call TPiS and describe it to them (any casting numbers??); if it's their baby they should know all about it.
Bill
Reply 0
Oct 10, 2009 | 08:01 AM
Quote: Call TPiS and describe it to them (any casting numbers??); if it's their baby they should know all about it. Bill
I'll check mine out tomorrow but I know it has no ID or casting # 's on it. Port size is the only way I think
Reply 0
Oct 10, 2009 | 08:51 AM
Quote: I'll check mine out tomorrow but I know it has no ID or casting # 's on it. Port size is the only way I think
Thanks and let me know please. I will try to find out as much information.
Thanks.
Reply 0
Oct 10, 2009 | 11:04 AM
Ok so you measured your ports. Its been mentioned what gaskets it might be for.
searches = The following info:
FelPro 1204
Port Size: 1.23" x 1.99
FelPro 1205
Port Size: 1.28" x 2.09"
Felpro 1206
Port Size: 1.34" x 2.21"
Ok so now search for miniram port sizes
TPIS Miniram
PORT SIZE: Felpro 1204
CFM: 265
PORT SIZE: Felpro 1206
CFM: 286
PORT SIZE: Felpro 1206, ported
CFM: 292
PORT SIZE: custom (welded, etc)
CFM: 321
https://www.thirdgen.org/techbb2/sho...hreadid=278927
Reply 0
Oct 10, 2009 | 01:18 PM
Did some more research and measured a 1205 miniram. came up with 1.27-2.08 which matches a felpro 1205.By your pictures yours appears to be 1.23-1.99 which matches a felpro 1204. So i would say you have a 1204 miniram!!!! And after looking at this closer was stated in post above. Hope this helps.
Reply 0
Oct 11, 2009 | 10:53 AM
Quote: Did some more research and measured a 1205 miniram. came up with 1.27-2.08 which matches a felpro 1205.By your pictures yours appears to be 1.23-1.99 which matches a felpro 1204. So i would say you have a 1204 miniram!!!! And after looking at this closer was stated in post above. Hope this helps.
Thanks guys, for the help. So it a 1204 MR and should fit the 350/300hp Goodwrench engine correct?
Thanks.
Reply 0
Oct 11, 2009 | 05:09 PM
Quote: So it a 1204 MR and should fit the 350/300hp Goodwrench engine correct?
If it has 6 bolts each side to hold the intake down
Reply 0
Oct 11, 2009 | 05:20 PM
Quote: If it has 6 bolts each side to hold the intake down
Yes, it has 6 bolts on each side. So good it does will fit.
Thanks again guys.
Reply 0
Subscribe
