car is running very rich help.
Old Sep 24, 2009 | 11:59 AM
trueburton's Avatar
Car: '88 Red Trans Am w/ T-tops
I just replaced the distributor and aligned it to where the original was. The car runs, but smells heavily of fuel. Fuel press. is 44psi. also i'm getting codes 15 and 21 but don't think the two issues are related. please help. thanks.
Old Sep 24, 2009 | 12:13 PM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
Re: car is running very rich help.
Are you sure you installed the distributor correctly, and did you check the timing with a timing light? If the spark is "late" or "early", unburned fuel could be coming out in the exhaust.
Bill
Old Sep 24, 2009 | 12:34 PM
trueburton's Avatar
yes i put it back to the original spot but i have never put a timing light to it since i'veowned the car, so the original spot may have never been right. I just put a new bolt on timing tab on today because the original was missing. now i just need to get my buddy with the timing light to come over and check timing.
MustangBeater20
Oct 29, 2022 09:20 PM
Bull86
Aug 10, 2015 05:43 PM
squiggy2
Aug 9, 2015 09:30 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
