negative crankcase pressure
Old Oct 3, 2009 | 05:28 PM
freebird87's Avatar
Car: proud owner of a 1987 trans am
Engine: turbo 355
Transmission: t5
I have a 87 trans am 305 tpi, and I was wondering what would cause negative crankcase pressure. Its been like that for a long time now and the car was running super strong. The other day i was driving down the road and suddenly lost oil pressure and started overheating, would the case pressure have anything to do with it its my daily driver so if anybody could help it would be much appreciated.
Old Oct 4, 2009 | 12:01 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: negative crankcase pressure
Originally Posted by freebird87
what would cause negative crankcase pressure. Its been like that for a long time now and the car was running super strong. .
What is negative crankcase pressure? How do you know you have it?
Old Oct 4, 2009 | 10:52 AM
flaming-ford's Avatar
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
Axle/Gears: 10 bolt 3.08 posi (4 now)
negative crank case pressure is no big deal and in fact is engineered to be that way, if memory serves me correct.
some have even used vaccumm pumps to increase this negative crankcase pressure. Theory behind it would be better ring sealing for the most part i beleive ,but don't quote me on it.
as for the theory behind it, im pretty spotty, so i'll let someone else speak up.
as for your car overheating it's probably a whole different scenario
think thermostat or electric fan operation if it does it again. make sure your fan or both of your fans are on and if your upper radiator hose is hot or cold (tells you if the t-stat) is open or not.
Old Oct 4, 2009 | 06:31 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The factory PCV system operates to create a controlled airflow through the crankcase to remove fumes and contaminants.I don't think it would be considered "negative" as in the system used on race cars for ring sealing.
Old Oct 4, 2009 | 07:14 PM
freebird87's Avatar
Engine: turbo 355
Transmission: t5
well thanks for the advice but i have my fans straight wired so that they stay on all the time and i'm not running a t-stat i still don't know what it is, the reason i know that i have it is because i can take out the pcv and the motor is sucking air in when it should be blowing it out.
Old Oct 4, 2009 | 09:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Are the lines hooked up the right way? Sounds like you have the vacumm supply or PCV on the wrong side. Disconnect the line on the other valve cover and see if it still has" negative " pressure
There is nothing in the engine to "suck" air in if the PCV is disconnected ; usually the engine pumps fumes out when hot
Old Oct 4, 2009 | 10:02 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Are you losing coolant?
Sounds like a blown head gasket or failed water pump
Old Oct 5, 2009 | 02:59 PM
freebird87's Avatar
Engine: turbo 355
Transmission: t5
its all right and yes its still sucking in air, it is confusing me greatly, i have a new water pump and im not losing any coolant. i've thought about all of this and still nothing...
Old Oct 5, 2009 | 04:58 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
With nothing connected to either rocker cover you are still sucking air in?
Old Oct 5, 2009 | 06:19 PM
AaronIROCZ's Avatar
Moderator/TGO Supporter
Negative crankcase pressure will not have any effect on you loosing oil pressure or overheating. The lack of the thermostat will cause overheating issues. The coolant is flowing too fast for it to transfer heat properly from the engine and to the radiator. Check out this thread for further information.
https://www.thirdgen.org/forums/cool...l-true-no.html
Old Oct 5, 2009 | 08:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by AaronIROCZ
Negative crankcase pressure will not have any effect on you loosing oil pressure or overheating. ]
But how do you get negative pressure in the crankcase; where is the air going to?
Unless he has a intake gasket leak?
Old Oct 5, 2009 | 09:06 PM
Car: 89 iroc-z
Engine: 305tpi
Transmission: wc-t5
you need to run a restrictor plate at a bare minimum for the t-stat.
i'm thinking like the above check your vaccumm hose routing and check for vaccumm leaks.
Old Oct 5, 2009 | 10:48 PM
AaronIROCZ's Avatar
In my situation I have aftermarket valve covers so I only have a spot for the pcv valve and the oil fill cap (plug in my case). I get engine vacuum since I have the pcv valve hooked up to the intake behind the throttle body and the other valve cover plugged off with the oil cap.
Old Oct 7, 2009 | 07:54 PM
freebird87's Avatar
Engine: turbo 355
Transmission: t5
yep sure is
Old Oct 7, 2009 | 07:59 PM
freebird87's Avatar
Engine: turbo 355
Transmission: t5
I see the theory but I've had the car for about a year now and it never had one in it and its always run 185 until the other day so I don't think that the t-stat has anything to do with it. When my oil pressure dropped is when it started overheating so it was just the friction. I'm just tryin to figure out what made me lose oil pressure still I know the pump only creates flow not psi so I'm once again stuck
and I forgot to put this earlier I do have a small intake manifold leak but its extremely small not even enough to make the vacuum gauge leak down
Old Oct 8, 2009 | 01:58 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Iand I forgot to put this earlier I do have a small intake manifold leak but its extremely small not even enough to make the vacuum gauge leak down
That could account for the neg pressure; fumes are being sucked straight in to engine
Old Oct 8, 2009 | 12:39 PM
AaronIROCZ's Avatar
If you think friction is what caused the overheating then my next step would be is to drop the oil to see if there is any metal mixed in it. If it ran for that long to cause the overheating due to friction then you might have other issues. How low of oil pressure are you getting, 0 or around 5-10ish. Either the oil pump has failed, the oil pump pickup tube has fell off or something in the driveshaft/distributor has failed. How does it run right now?? Any misses or white smoke??
Old Oct 8, 2009 | 03:13 PM
freebird87's Avatar
Engine: turbo 355
Transmission: t5
the oil pick up may be, but no white smoke and the car runs strong, I can turn it on and the oil pressure will stay around 10psi for 5 to 10 minutes then drops to zero, I took it down the road one time and it went to 14psi and no matter what the rpm was it stayed constant till it dropped all the way I let it sit for a min oil pressure went back up and I drove it home.
Old Oct 8, 2009 | 04:12 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
On another Forum, a guy posted about the same problem. Consensus is his oil pump pick-up fell off and is laying in the bottom of the oil pan.
One easy way to check is to drain the oil, then rap on the side of the oil pan and listen/feel for movement of the pick-up. Of course, you can always drop the oil pan to see what's going on.
Either way, you need to find out the cause before engine damage results.
Hope this helps.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!
Old Oct 20, 2009 | 06:09 PM
freebird87's Avatar
Engine: turbo 355
Transmission: t5
well bad news for me i dropped the oil pan today i've been held up or i would of done it sooner and i found piston #7 in the pan never heard a thing honest to God. so yea new motor coming soon hopefully. for all the help
Stryker412
Sep 20, 2015 06:59 PM
gta892000
Sep 16, 2015 12:37 AM
92rsvortec350
Sep 10, 2015 10:54 AM
TBRays98
Sep 6, 2015 05:05 PM
