Completed Ohm check, vac and fuel pressure. Check me?
Old Oct 11, 2009 | 11:52 AM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
Interesting, made me go hmmm.
I attempted to ohm test my injectors today.
I removed the battery ground, pulled the harness from the injector, turned my meter on to ohms (tried 200, 1k, 2k, 20k), checked the probes (digital says -1 when touching probes together, analog 0'd out fine.) Put one probe to one side of the injector and the other probe to the 2nd injector.
The analog meter zeros back out, the digital then reads -1, like it does when touching the probes together. Am I doing something wrong here, I can't pull voltage readings from the TPS either. All 8 injectors do the same thing with my meters. Could the meters be fried, any way to check that too?
I'm stumped and appreciate any direction given, thanks guys!
-Res
Old Oct 11, 2009 | 07:58 PM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: Zero'd out in an ohm test.
-Res
do you have a good battery in the ohm meter?
Old Oct 14, 2009 | 07:04 PM
resinlake's Avatar
Re: Completed Ohm check, vac and fuel pressure. Check me?
Ok, the meters were bad, bought a new one from Harbor.
Base reading with probes touching on meter got as low as .5, not quite 0 with meter set to 200 ohms.
Please let me know what you think of the readings for ohms, fuel pressure and vacuum. I have done a lot of reading on the site, but just wanted to throw my readings out there. My idle would get choppy, surging from 5-600 to 1-1000 rpm, as soon as pushed down the small lever on the TPS sensor just a small amount, the idle would stop surging about. I removed the IAC motor tonight, and there was a great amount of carbon built up on the cone and on the shaft its self and spring, I'll be cleaning it tomorrow and setting the TPS to the correct voltage.
Thanks again everyone!
Rear of Engine
8 - 16.7 ---------- 7 - 16.3
6 - 16.5 ---------- 5 - 16.3
4 - 16.5 ---------- 3 - 16.2
2 - 16.5 ---------- 1 - 16.2
Front of Engine
Fuel Pressure
39-40 PSI @ 900 rpm or so.
45 PSI @ 500-600 rpm.
Vacuum
12-13 @ 700 rpm.
15-16 @ 900-1000 rpm.
Old Oct 14, 2009 | 07:36 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Numbers look good ; I'm picking the clogged IAC /TB is your idle problem.Worth cleaning the whole TB
Don't forget to reset the IAC after install
http://www.corvetteactioncenter.com/...and+Idle+Speed
Old Oct 14, 2009 | 07:46 PM
resinlake's Avatar
I was wondering about a reset procedure, thank you for the link! I'm hoping that was the problem too, I believe I ended up leaving the IAC in the throttle body when I tore the engine down and cleaned things out, springs pretty crusty looking, you know... just wondering, on the charcoal canister, does the gas vent tube go on the top port or the bottom port? I read somewhere else before I believe, but was not 100% sure.
Thanks again!
Old Oct 14, 2009 | 08:11 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Top port is feed to pass side valve cover for PCV system.
Bottom port is for purge line from canister
Old Oct 18, 2009 | 07:46 PM
resinlake's Avatar
Well, finished cleaning the IAC and the port inside the throttle body, worked great! Makes a difference to run a bristle brush like the type used for cleaning spray guns and running it through both sides of the throttle body ports for the IAC.
The TPS sensor was very easy to tune, went to .54 volts exactly and the voltage rolled even with the throttle. I believe it ended somewhere around 4.24-4.27 volts at WOT. Idle is perfect, no stalling, no searching for its idle rpm. The throttle response is sharp!
Old Oct 18, 2009 | 07:49 PM
Street Lethal's Avatar
Car: 1990 Trans Am GTA
Engine: Turbo 305 w/MS2
specialized
Jun 18, 2022 09:26 AM
Terrell351
Jun 13, 2021 01:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Casey Meyers
Mar 2, 2016 10:46 AM
KO1
Aug 31, 2015 06:31 PM
