EGR removal
Old Oct 19, 2009 | 05:34 AM
Glenno's Avatar
Car: 1990 Jeep YJ
Engine: 70's 350 w/87 Z TPI-MAP Conversion
Transmission: Muncie SM 465 Granny Low 1st
Axle/Gears: 4:10 Gears in both axles
EGR removal
I'm going to be installing my TPI manifold and I don't know if I need to install steel block off plates along with the gasket set when doing so? The two square looking plates that actually block off the holes on the cylinder heads. Or do I just need to install the standard EGR block off plate that installs with two bolts directly in place of the EGR valve?
Old Oct 19, 2009 | 06:10 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Re: EGR removal
No one has done this?
Old Oct 20, 2009 | 05:44 PM
3rd gen Will's Avatar
Car: 91 Z28, 2000 T/A
Engine: SBC 355, LS1
Transmission: T56, T56
Axle/Gears: 10bolt 3.73, 3.42
Re: EGR removal
I didn't put the plates in when I didn't have a EGR on my old 84. I would venture to guess they just restrict the exhaust gases from entering the manifold and heating it up more. I would leave them out in case you put the EGR valve on.
Old Oct 20, 2009 | 06:43 PM
Glenno's Avatar
Car: 1990 Jeep YJ
Re: EGR removal
Thanks for the help.
Old Oct 21, 2009 | 03:10 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Re: EGR removal
Do you have to pass a smog test?
Old Oct 21, 2009 | 03:20 AM
Glenno's Avatar
Car: 1990 Jeep YJ
Re: EGR removal
My 1990 Jeep came originally with a piggy carburetored inline six cylinder engine. It now has a 350 TPI engine. I'm hoping it will run cleaner then it was ever required too even when it was new. I'll find out!
Old Oct 21, 2009 | 03:57 AM
rgarcia63's Avatar
Car: 88' IROCZ
Axle/Gears: 2.77
Re: EGR removal
It doesn't matter if it runs cleaner than the 6 banger, the rule is it must pass the emissions for the engine, but older engines in newer vehicles is not allowed. An 87' TPI will pollute more than a 90's 6 cylinder.
I assume you didn't go to the expense of retrofitting rhe 70's block with a roller cam and lifters.
If they do inspect under hood the TPI will stand out like a sour thumb in a Jeep.
Let's say the Smog Tech is not so bright, and you removed the SES/CEL bulb, but the analyzer will still detect high Nox because you disabled the EGR.
Old Oct 22, 2009 | 05:28 AM
Glenno's Avatar
Car: 1990 Jeep YJ
Re: EGR removal
Well that's not good.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Stryker412
Sep 7, 2015 09:11 AM
rjcme
Sep 5, 2015 01:23 PM
