Will This PROM work??
Old Dec 18, 2009 | 09:50 PM
quick90rs's Avatar
Car: 1990 Camaro RS
Engine: 350 Vortec Demon 650CFM
Axle/Gears: Posi
I just got a PROM from an 87 Camaro TPI 305,will it work in my 89 Trans Am GTA
? I know the 87 had cold start injector, will this effect anything?
Old Dec 18, 2009 | 10:45 PM
doc's Avatar
doc
Car: '87 IROCZ
Engine: 395 ZZ4
Transmission: ProBuilt 700R4
Axle/Gears: 9 bolt 3.70s
Re: Will This PROM work??
If your car is a TPI also, then it should work. However, you might find it cranking a bit to get started because the '87 Eprom chip counted on a slightly lesser amount of fuel from the 8 injectors.
Old Dec 19, 2009 | 11:54 AM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
Axle/Gears: 2.73 Posi
I have one for sale
For sale is a Memcal Prom for 89 Trans Am, 305 TPI, Auto, 2.73 gears.
This is for MAF setup, and will work with the 1227165 ECM. The broadcast code for this prom is APYM 1613 3467.
This item has been discontinued by GM, and is no longer available and almost impossible to get. $225.00 shipped
Old Dec 19, 2009 | 12:04 PM
kozman's Avatar
Car: 89 Trans Am
Engine: 5.0 TPI
...one second thought, if you have a GTA, it should have a 350, right??. So this prom won't work right cause it's for 305 that has 19lbs injectors and a 350 has 21 or 22lbs injectors - so the injector pulse will be off.
Remember 89 is an odd year, no cold start injector(9th injector) ect.
I know a few proms have been dicontinued for 89 and are not cheap to get.
See what you have and get back to me if your interested in this prom.
Steven 86IROC-Z
May 24, 2026 04:52 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Sanjay
Aug 12, 2015 03:41 PM
djmarch
Aug 11, 2015 10:22 AM
the_nikfive
Aug 11, 2015 02:46 AM
