305 LB9 to THIS 350
Old Dec 26, 2009 | 11:58 AM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
305 LB9 to THIS 350
Hey Guys,
I was wondering if the engine in the link fits directly into my car?
http://www.jegs.com/i/GM-Performance...ductId=1231165
Here is my plan:
I want to put all the TPI stuff on and want to keep the serpentine belt accessories.
Has anyone of you experence on this engine with TPI an the techniqe from a 89 camaro? Do the bolt holes for the accessory fit?
Thanks, Rob
Old Dec 26, 2009 | 12:21 PM
Russ-So Cal's Avatar
Re: 305 LB9 to THIS 350
The problem is that it has Vortec heads. You will need the Scoggin-Dicky/Edelbrock Vortec compatible base. You will get better performance for less money by getting a short block and a set of Trick flow 23 degree or AFR heads.
Old Dec 26, 2009 | 12:45 PM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
And what else do I have to do? what else is necessary?
I´m a complete noob in engines, the only thing I can do is to disassemble the accessory and put them back together. I don´t know how to build up an engine from the block.
Old Dec 26, 2009 | 02:20 PM
chevy boi's Avatar
Car: 1989 i roc-z28
Engine: 350 tpi l98
what he means is get a assembled short block ( a block with the crank pistons and rods and maybe even a cam.) from there you can get a set of heads depending on the year to fit your tpi intake manifold. i think it was 87 when they changed the bolt angle on the heads.
or you can buy that engine, and get a vortech style base for your tpi and it should all bolt up
Old Dec 26, 2009 | 03:35 PM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
Ah ok, I see...
but how can I calculate the estimated horsepower? i mean he says i can get mo power for less money
Old Dec 26, 2009 | 07:34 PM
Davidgou's Avatar
Car: '88 Black GTA, T-tops, digital dash
Engine: 5.7 TPI w/custom chip
Axle/Gears: 9 bolt 327 posi
The Horsepower is always a great question. I don't think you can really tell until it's all put together and dyno tested, but there are also people in these forums that know a lot about this kind of stuff.
Old Dec 27, 2009 | 02:05 PM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
I think its too difficult for me to build up my own motor without the help of a pro!
Ok I found the Scoggin Dicky Adapter Base Plate, a little expensive, but therefor the engine is cheap.
Oh btw if here is a pro who knows a lot about engines, don´t be shy and let me know your opinion of how to build a budget motor with about 350hp and give me a partlist.
But I want to keep the TPI.
Thanks Rob
Old Dec 30, 2009 | 11:45 AM
Black_Knight's Avatar
Car: 1985 Pontiac Trans Am
Engine: 305TPI
Thanks Rob
This is more or less what I'm trying to do. Though my situation is complicated slightly by wanting to add turbos or a supercharger in the future. Therefore I need to use strong parts in the short block in order to be able to handle the boost later on. I also need a lower compression ratio to facilitate that.
Old Dec 30, 2009 | 12:32 PM
Rock-Bert's Avatar
Car: 89`RS
Axle/Gears: 2,72
And how are you going to do that, what parts do you take?
Old Dec 30, 2009 | 12:39 PM
Engine: 305TPI
I'm still trying to figure that out.
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
gta90
Sep 15, 2015 04:00 PM
kyleb24
Aug 15, 2015 08:24 AM
st.evel07
Aug 13, 2015 06:15 PM
