22s w/out chip
Old Jan 5, 2010 | 10:10 PM
dirtybrd88's Avatar
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
22s w/out chip
now i know it wont run at it peak without a good tune but can my 305 run my 19lbs injectors on stock tune just run not race thanks guys
Old Jan 5, 2010 | 10:20 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: 22s w/out chip
are you asking if your stock chip will run 19lb injectors or 22lbs??? (thread is called 22's, put in your post you say 19's)......
and the answer to both is yes.
Old Jan 6, 2010 | 02:02 PM
dirtybrd88's Avatar
Re: 22s w/out chip
22s sorry was irratated when writting it
Old Jan 7, 2010 | 09:10 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: 22s w/out chip
Well it will most likely run but no it wont run well. And I dont mean by race standards but i mean more by just drive ability standards. The ECM calulates the fuel based on the injector flow rates and by increasing the injectors without programming the ECM the ECM will still think theres 19s installed when there are actually 22s. As result the PWM signal sent to the injectors will be the same but more fuel will be dumped in than expected. The car will run a bit rich. Just out of curiosity why would you want to install 22s on a 305? Bigger injectors will not increase performance. The only time you should really use bigger injectors is if you have exceeded your current injectors capabilities other wise you want to run the smallest injectors that will do the job.
Old Jan 8, 2010 | 08:02 AM
southbay08's Avatar
Re: 22s w/out chip
For a 305 you should definitely use 19lb injectors....can you use 22lb? yes, but you will not get the greatest fuel mileage.
Old Jan 8, 2010 | 09:01 AM
irocuroc's Avatar
Car: 89 iroc
Engine: l98
Transmission: tremec
Re: 22s w/out chip
It not the mileage I would be concerned with, its the extra fuel that is being pulsed through the injector, the stock computer thinks it has a 19lb injector, if you put in a 22 without a tune you will have 10% more fuel in the mixture, on closed loop the computer via the 02 sensor should correct by virtue of the blm being low (probably around 120). This will remove enough fuel to keep the A/F ratio back to a stoichometric mixture. However in open loop it will be rich allowing unburned hydro carbons to wash through your engine which over a long period of time could end up in your oil, it will also collect in the cats causing premature failure (maybe). So, imo the engine will run fine, the computer will compensate when in closed loop, but anytime an injector size is changed the tune should to be set properly. Bigger injectors by 10% would not affect gas mileage because the BLM will just keep taking out fuel. What happens when you drive from sea level to lets say colorado?, the computer compensates for the less dense air. So,again its all bunch of BS that a 305 won't run well on 350 injectors and your gas mileage will go to down.
Linson
Oct 24, 2025 02:00 PM
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Gunner242
Dec 25, 2015 04:49 PM
KO1
16
Oct 15, 2015 05:00 PM
jaridjohn
Oct 5, 2015 07:01 AM
