'87 350 TPI cam?
Old Jan 19, 2010 | 02:29 PM
Stephen's Avatar
Car: 87 GTA
'87 350 TPI cam?
I was under the understanding that the 87 350 TPIs got the "peanut cam", but some recent searches are saying no, some are saying yes.
I'm thinking of swapping out mine, if mine IS the "peanut cam", so I'm looking to find out just how "bad" my 87 cam is, before I look into getting a new cam.
Yes, cam + heads +roller rockers, etc. would be better to do all together. But my budget won't allow that & I like to see the improvements (if any) at each step.
Anybody know the cam specs of each year? I'm thinking a LT1/HOT cam to swap in.
Old Jan 19, 2010 | 04:41 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: '87 350 TPI cam?
'87 L98 202/206 403 / 415
Even going to a stock LT1 cam is a improvement on account of the increased lift .205/ 207 450/ 460ish
The hot cam (218 / 226 .525 w/ 1.6 rockers ) may be a mismatch without intake mods because it will run revs the TPI intake won't support.Note you need the 1.6 rockers to get that lift , without it is only .492
Something similar to the popular TPIS ZZ9. 212/226 .483/.520 might be a better choice.
And if you want to be really cheap I have had great success with the ZZ4 cam 208/221 474 /510 in L98's Can be found as take out cams from ZZ4 crate engines under $140, I paid $85 for mine
Old Jan 19, 2010 | 04:43 PM
Twin_Turbo's Avatar
wow, that is a sad cam.
Old Jan 19, 2010 | 05:04 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Bit of a insult to the peanut I think
Old Jan 19, 2010 | 05:43 PM
yamban's Avatar
Car: 1985 Z28
I have an '87 350 with the small cam... its not really that bad in combination with the intake. I use my car for daily driving and with this cam its quite a quick car!
Old Jan 20, 2010 | 12:19 PM
thomas1976's Avatar
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Best would be to decide power/rpm range first.
Comp cam has a nice download "cam quest", if you havent already you could try it out.
Out-Cast
Aug 17, 2015 10:57 AM
Jlanz55
Aug 17, 2015 07:15 AM
bamaboy0323
Aug 15, 2015 07:20 AM
wruiz
Aug 13, 2015 09:07 PM
gta power
Aug 13, 2015 06:15 AM
