TIP FUEL PUDDLE
Old Jan 20, 2010 | 06:50 AM
ZEEYAA's Avatar
Car: 1991 Z-28
Engine: 383 / TPIS MINI RAM
Transmission: 700-R4
Axle/Gears: MOSER 9IN 3.89
TIP FUEL PUDDLE
Has anyone ever had the problem of fuel puddling in their plenum. It is not the regulator. There is at least 4-6 oz of raw gas backed up in front of the plenum behind the TB. It filled up the AIC area and even ran out of the front blades of the TB. We took the plenum off and looked for a wet trail but there was none. Where could this possibly be coming from? Any help would be greatly appreciated.
Old Jan 20, 2010 | 10:28 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: TIP FUEL PUDDLE
With it not being the FPR then it is the CCP system.
RBob.
Old Jan 21, 2010 | 11:11 AM
ZEEYAA's Avatar
Car: 1991 Z-28
Re: TIP FUEL PUDDLE
Thanks alot, I will check into that direction.
Old Jan 22, 2010 | 04:21 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: TIP FUEL PUDDLE
Cracked injector or shot o-ring.
Dry it all up, pressurize the system, and look for new moisture.
Ghettobird52
Apr 21, 2020 08:44 PM
Warlocksirix
Sep 3, 2015 12:26 PM
theshackle
Aug 22, 2015 06:52 PM
BurlyChev
Aug 22, 2015 11:42 AM
Leggman1
Aug 6, 2015 04:15 AM
