Let's see those painted plenums and runners!
Car: 1987 IROC-Z
So I'm rebuilding the 305 out of my IROC and I'm wanting to see how the plenum and runners look painted, plus is it necessarily a bad thing to paint them? Cause I was told that it would hinder the heat dicapation of the units. But since they aren't heated parts cause they are part of the cold air intake paintin them shouldn't be a big deal right?
Thanks guys!
Thanks guys!
Car: '88 Red Trans Am w/ T-tops
Re: Let's see those painted plenums and runners!
have you ever touched the plenum after running the car? they get hot. I wouldn't paint em.
Car: 2001 GMC Jimmy
Transmission: Nv3500 5 speed
Axle/Gears: Dana 44's f&r, 4.30 gears
Car: 1987 IROC-Z
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
. The plenum and runners are to transport atmospheric air into the engine. How is painting the OUTSIDE going to "hender" performance?
If anything, you'll be adding about 1-10 grams of weight to the front end. Also it does not dissipate any heat what so ever. Naturally it'll be hot to the touch because of the engines radiant heat and not to mention that the runners will transfer heat because they are bolted onto the intake manifold (which is filled with radiator fluid). Thread Starter
Car: 1987 IROC-Z
If anything, you'll be adding about 1-10 grams of weight to the front end. Also it does not dissipate any heat what so ever. Naturally it'll be hot to the touch because of the engines radiant heat and not to mention that the runners will transfer heat because they are bolted onto the intake manifold (which is filled with radiator fluid).Trending Topics
Car: 89 Formula 350
Engine: Forged 385 H/C/I
Transmission: 700R4-4300 Stall-lockup
Axle/Gears: BW 9 Bolt 3:70
Powder coated Super Ram 383
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
If it did work like that it would be a bonus because the cooler the intake is, the colder the air into the engine would be which is good for perf
Hotrodboba400
Dec 10, 2019 07:07 PM
toronto formula
Sep 10, 2015 07:31 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
