Running rich, not sure why
Old Feb 17, 2010 | 08:09 PM
korda's Avatar
I have a 1985 L98 from a Corvette. It has been swapped to Speed Density, running the '730 ECU and a TPI chip from Larry's Electronics. I recently had some issues where the engine wouldn't idle and through trouble shooting have found that it's running very rich. The engine is currently in my Jeep after sitting for a couple years well protected in my garage. As far as I know, the engine is all stock.
The plugs are all fouled. The exhaust smells like gas and most recently, I was getting black smoke on startup.
After letting the engine warm up and hooking it up to TunerPro at idle I get the following info:
Throttle Position - .78
TPS % - 0
Coolant Temp - 87.5* C
Startup Coolant Temp - 20.75* C
Battery Voltage - 13.7 V
Fuel Pump Voltage - 13.5 V
Vehicle Speed - 0 MPH
Engine Speed - 700 RPM
Map Volts - 1.6 V
Map kPa - 40.24 kPa
Manifold Air Temp - 65.24* C
Target AFR - 14.73
O2 Sensor - Sweeping up and down
Integrator - 129
BLM - 156 (read as high was 160, as low as 144)
Block Learn Cell - 4 (this changes while driving)
Injector Pulse Width - 2.55 ms
I ohmed out all the injectors with them all ranging from 23 - 29 and one at 42. From what I've read that is pretty high.
The opinion I've gotten from a few people is that I've got leaking injectors. I pressured the system, clamped off the fuel and return lines and it does leak down to around 10 psi in 15-20 minutes. I used a thermometer to measure the exhaust manifold at each cylinder and there weren't any huge differences.
Does anyone have any insight? Does this sound like bad injectors?
Old Feb 18, 2010 | 05:02 PM
korda's Avatar
Re: Running rich, not sure why
Nobody?
Old Feb 19, 2010 | 12:08 AM
IROCZ28KevinZ's Avatar
Car: 1991 Z28 convertible
Transmission: TH-700R4
Axle/Gears: 3.73 posi 4th gen 10-bolt
If you have the means to do it, perform an injector power balance test. That should reveal a leaking injector. My 91 Z28 is running a wee rich as well, and I've already checked the fuel pump and pressure regulator. My O2 readings sweep all over like yours, and my integrator is at 128. A quick test you can do is unhook the O2 sensor once warmed up, and jump the harness connector to ground and see if your O2 millivolts goes to around .350, that way you know that your ECM and wiring is good. If the O2 sensor age is unknown, a new one is about $20 at autozone, i would try replacing that because a contaminated or weak one will affect how much fuel the engine gets. According to the 91 service manual, O2 milivolts must be at or above .750 for 30 secs before a rich condition code will set. It can run close to there and be rich and still not throw a code.
Also the manual says as part of the diag for this to unhook the MAP sensor electrical connector and see if that improves it.
Old Feb 19, 2010 | 06:47 PM
southbay08's Avatar
TPS % - 0
Map Volts - 1.6 V
Map kPa - 40.24 kPa
Target AFR - 14.73
Integrator - 129
sounds like leaky injectors. Pull one or all of the plugs, if the cylinder/cylinders are wet, then you have one or more leaky injectors, besides the ohm readings are WAY to high.
Old Feb 19, 2010 | 07:36 PM
korda's Avatar
They were wet.
I ordered new injectors today from FIC. Hopefully that fixes things.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Zeek1041
Theoretical and Street Racing
Aug 21, 2015 08:45 PM
tmellott89
Aug 16, 2015 02:58 PM
squiggy2
Aug 9, 2015 09:30 PM
