5.7 iroc no start
Old Feb 19, 2010 | 01:20 PM
LS7Roc's Avatar
Car: 88Roc Flame Red Black/Gold Pkg
5.7 iroc no start
Fuel pump primes but how do I know for sure it works? Car just cranks, it has spark and the fuel pump sounds good...what else can I do?
Old Feb 19, 2010 | 01:38 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Re: 5.7 iroc no start
My best guess without more information is that the ignition module is bad, plus it is the easiest thing to check most auto parts stores can do that.
Old Feb 19, 2010 | 02:27 PM
formula_novice's Avatar
Car: 1989 Firebird Formula
Engine: 383 Stealth Ram
Axle/Gears: 3.73 9 bolt Posi
Hook up a fuel pressure guage to it and make sure you are getting fuel.
Old Feb 21, 2010 | 06:49 PM
bcmag's Avatar
unplug tps and see if it starts...if shorted sytem is in clear flood ...no pulse....does it have vats?
Old Feb 22, 2010 | 01:38 PM
LS7Roc's Avatar
Gonna try that and no VATS BTW...also I may still not be getting fuel even though the pump primes right??? thanks for helping.
Old Feb 22, 2010 | 02:46 PM
jmat2407's Avatar
Car: 1989 Trans Am GTA
Engine: 5.7 TPI
Axle/Gears: BW 3.23
Check fuel pressure. Ohm out your injectors as well. Just this past week 2 of my old injectors ohm'd out at <10 ohms, needless to say the car would only start using starter fluid. Purchased a new set of injectors and problem solved she fires right up.
Also a tip. If you ohm out one of your injectors and it is reading real low (less than 12), unhook it and then try to start the car. If the injector was indeed your problem the car will now fire right up.
Old Feb 25, 2010 | 01:19 PM
LS7Roc's Avatar
Hey, I disconnected the injectors one by one and cranked it, still no start. It has spark and the fuel shoots when I push the test valve while cranking. Nothing still...
Old Feb 25, 2010 | 01:20 PM
jmat2407's Avatar
Engine: 5.7 TPI
Axle/Gears: BW 3.23
What was the ohm reading on each injector?
Old Feb 25, 2010 | 02:22 PM
LS7Roc's Avatar
Hi, I didn't check the ohm readings, I just disconnected them one by one and cranked it...no start..is is safe to say that my fuel pump is good since it primes and I have fuel shooting out..?
Old Feb 25, 2010 | 04:00 PM
Your car is not producing an injector pulse, check the plugs on the back of the distributor, if they are good and tight then change out the ignition module.
Frozer!!!
Jan 19, 2024 04:55 PM
Wade787b
Sep 29, 2015 01:15 PM
89redeyeRoc
Car Audio
Aug 24, 2015 07:01 AM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
