TPI Fuel pump
Old Feb 21, 2010 | 03:15 PM
Maine 92's Avatar
TPI Fuel pump
Looking to upgrade the factory fuel pump on my 92 TPI, should I do a intank pump or a inline "helper pump", do I need to drop out the tank or can I access it from above, Thanks
Old Feb 21, 2010 | 04:29 PM
ricks89's Avatar
Car: 89 iroc
Engine: carb 80 over 350
Transmission: 350
Axle/Gears: 10 bolt 373 (had 9 bolt)
Re: TPI Fuel pump
cant really tell you which way to go but i know when i had to mess with mine i was guna drop the tank then someone told me to check from top. well previous owner had cut a panel to access from top didnt really like that idea i dont think i do it if it wasnt there so i far as i know theres no top access.if u think inline helper would work id go that route cause as far as i know u have to drop the exhaust to
Old Feb 21, 2010 | 05:45 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Re: TPI Fuel pump
Hello Maine 92!!
The best solution is to once and for all get rid of the intank fuel pump, that way you'll never have to drop the rear end (dealer service method) etc to change the fuel pump again!!
You can access the fuel pump two ways, one is as per the aforementioned drop the rear etc, the other way is to build an access panel from above, it involves removing rear interior carpeting, cutting the floor pan, etc....!!
A remote mounted fuel pump in the engine compartment, or after the fuel filter under the car are the best options!!
Just think how easy, and less time consuming it would be changing the fuel pump if the need arose, if it was mounted in the engine compartment, say on the strut tower!!!
Old Feb 21, 2010 | 06:02 PM
ricks89's Avatar
Car: 89 iroc
Transmission: 350
Re: TPI Fuel pump
thats pretty much what i did. but i have carb motor and my pump basically was fast enough to deliever. so put on machanical pump on motor
Old Feb 21, 2010 | 08:15 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: TPI Fuel pump
put a holley 255lph pump back there. Its tough to drop the tank and all that, but hey thats half the fun of it
Old Feb 21, 2010 | 08:35 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Transmission: 700-r4
Re: TPI Fuel pump
I got a walboro 255 and i like it alot, its quieter and puts out alot more fuel pressure so a adjustable fuel pressure regulator is a good thing to have. and just drop the tank, dont hack up the car its not like you have to change it all the time. 4 hours of hard work is better than a lifetime of knowing you put a gapping hole in your car because your lazy.
Old Feb 22, 2010 | 09:21 AM
Maine 92's Avatar
Re: TPI Fuel pump
Might consider making a access panel, have the equipment to make it correctly, my exhaust is welded and I don't want to cut it if I can avoid it. Would the access go from the truck or passenger compartment?
Old Feb 22, 2010 | 11:45 AM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Re: TPI Fuel pump
is it welded to the headers or just one piece after that connection. I just unbolted mine at the y and slipped it off its hangers and had plenty of room. If youre really set on hacking a hole into your car you cut it right in the middle of the hump thats before the trunk. Theres thousands of pics of this, do a search for "access panel"
Old Feb 22, 2010 | 11:44 PM
Re: TPI Fuel pump
Hello Maine 92!!
If you insist on having an access panel, do it right, remove your tank, and make it a real pro job, not a hack job!!! With the tank removed, you can see what your doing!! Cutting blindly down above the tank is not the safest thing to do!! Your exhaust should be okay, even if it's welded!! The one time that you remove the tank will be a learning experience, and you might even decide to forego the access panel!!
Personally, I would look for a way to mount the fuel pump externally from the tank, for better access, than the removable panel can provide!!
Old Feb 23, 2010 | 03:29 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Re: TPI Fuel pump
my walboro just went out after 2 months so scratch that off your list, i dont know what to try now
Old Feb 23, 2010 | 04:07 PM
all4u's Avatar
Car: Firechicken
Engine: 350 + 30 over, 400 crank
Transmission: autotragic, stalled
Axle/Gears: not a one tire fire, thank god!
Re: TPI Fuel pump
The only answer is the Racetronix with hot wire kit. Whatever they rate it at, it is severely under rated. The racetronix pump can handle a 502 ram jet on a 150 wet shot. My buddy has had that pump for maybe two years and it works great.
I also use the racetronix with hot wire kit and it works great on a mild 383 with a 100 shot for about a year now. I'd be careful and back down the regulator before first starting the car. When I first started my car after the pump was in, fuel pressure shot up past the 100 psi on my gauge! That pump will never, ever, die, ever.
Old Feb 23, 2010 | 04:24 PM
KNBlazer's Avatar
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
Re: TPI Fuel pump
was it made in the USA?
Old Feb 23, 2010 | 07:19 PM
Maine 92's Avatar
Re: TPI Fuel pump
Is a Racetronix a inline helper type pump?
Old Feb 23, 2010 | 07:28 PM
Maine 92's Avatar
Re: TPI Fuel pump
IMO dropping the tank and all that is a waste of my time, I'd rather spend it on something that makes a difference. I'm not a hacker, just have my prorities on other things, like things that you can actually see. Not to belittle someone else's efforts, just not important to me.
Old Feb 23, 2010 | 08:11 PM
all4u's Avatar
Car: Firechicken
Re: TPI Fuel pump
Racetronix is a drop in pump, and it is one of the most important things to do to your car along side subframe connectors. What if you want to upgrade later and need more fuel? What if you start to spray and need more fuel for nitrous and the engine, it will support it. Having a quality fuel pump keeps you from being stranded somewhere, I worry more about reliablity and performance than what others think of my mods.
The motor pool in the Army have a saying. "If you can't afford to do it right, can you afford to do it twice?"
Old Feb 23, 2010 | 08:21 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: TPI Fuel pump
I'm gonna steal this line and add it to my signature...
Old Feb 23, 2010 | 11:36 PM
all4u's Avatar
Car: Firechicken
Re: TPI Fuel pump
Not cool, don't copy that line, just kidding, but yeah, the Army has been saying that crap for years.
I'm thinking of putting 19D's lead the way for my signature but that seems a bit arrogant.
Old Feb 24, 2010 | 06:22 AM
F-Body Demon's Avatar
Re: TPI Fuel pump
Oh yeah...your sick man haha.
But as far as Mains' question goes...
I bought a fuel pump from BBK for my Trans Am, turned out to be a Walbro unit. Which then turned out to be the BAD Walbro unit. Now im running a Autozone pump and it hasnt quit yet.
Old Feb 24, 2010 | 07:30 AM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
Re: TPI Fuel pump
i have the racetronix pump and harness, installed about 8 years ago still going strong, i was one of the first for a 3rd gen. it has done long hauler on power tour= dependable
Old Feb 24, 2010 | 09:52 AM
all4u's Avatar
Car: Firechicken
Re: TPI Fuel pump
Like I said, Racetronix owns all, they under rate their pumps. When I found out that it ran a 502 ram jet, with a shot of juice, I knew that it could handle a mild 383 for a long while.
And yes, if chad ran it on the power tour, that shows reliability along side with the power.
Old Feb 24, 2010 | 07:08 PM
ATX-Iroc's Avatar
Car: 87 Iroc-Z
Engine: 305 tpi
Re: TPI Fuel pump
It was from canada i believe, thats where racetronix is based out of right. Im not knockin em because there always a bad one in the batch and i didnt install the hotwire kit yet since the motor is still stock so that may have led to its early death
Old Feb 26, 2010 | 10:24 PM
thewizard's Avatar
Car: LT4 C4, LT1 CE, 95' Dyno Air
Transmission: ZF S6-40, 4L60E, sprockets
Axle/Gears: 3.45, 3.07
Re: TPI Fuel pump
I have a Racetronix in-tank setup in one of my other cars and it works great. Their harnesses are top notch to say the least.
Old Mar 2, 2010 | 03:59 PM
1b rock's Avatar
Transmission: a4
Re: TPI Fuel pump
make a panel way better and should have been there from factory... if your worried about where to cut ill send u a pic of mine by the way iv put 3pumps in my car and it takes about 15 minutes now just pull carpet back and ur there
Old Mar 28, 2010 | 02:25 PM
The_rabbit1's Avatar
Car: '87 Iroc
Engine: 350 .060 over
Axle/Gears: 3.70 9bolt
Re: TPI Fuel pump
just installed my walbro yesterday, and it said "MADE IN USA" stamped on the sided of thepump casing.
Old Mar 28, 2010 | 03:21 PM
KNBlazer's Avatar
Engine: 5.1 4bbl
Re: TPI Fuel pump
They're made in a few factories I believe... I was told by a reputable and reliable source that I should make sure it was MADE IN THE USA when I looked into buying a unit...
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
Grant2k
Jul 10, 2018 04:01 PM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
