New Throttle Body Question
Old Mar 3, 2010 | 02:50 PM
wildjyoung's Avatar
Car: 1991 Trans Am GTA, 2003 Grand Am GT
Engine: 350 Tune Port
Hello,
I completed my build of a 357 for my 1991 GTA. I have AFR 180's with Accel high flow intake and runners. Cam is the Lingenfelter 74216. Static compression is about 10.5:1 and dynamic compression is about 8.34:1. TCI Streetfighter 700R$ with 2,600 stall.
I have a stock 48mm throttle body on the car now that is sticking. So, time to replace. I have been looking at Summit at their brand of throttle body as well as BBK.
So, my questions?
1. Based on my motor, will I gain anything by going to a larger throttle body?
2. If so, what size 52mm or 58mm?
3. Is the Summit throttle body a quality piece or should I go with BBK?
Thanks for the help!
Old Mar 4, 2010 | 10:27 PM
GTA Sammy's Avatar
Car: 1989 T-Top GTA
Engine: 5.7L TPI> 6.2L
Transmission: 700R-4
Re: New Throttle Body Question
Have you dynoed your car yet?
Did it fall off more than you thought it should?
I say if ya gotta replace it anyway, at least upgrade!!!!
Seeing as you don't have a big cubic inch engine..... but have certainly improved the amount of air your engine should be using..... I say go with the 52mm.
On a very lean tune.....I hit 330 Hp and 349 Ft/Lbs @ the Rear Wheels with the original 48mm TB with much the same combo as yours(357",LPE Cam, AFR Elim 180's.) So 48mm can do the trick
58mm is probably overkill in this situation.
As for the Summit Brand, like most things these days it's made by one of the other big companies with the Summit stamp on it.
Go for it......... Buy the Summit Throttle Body and save yourself $100.oo and spend it elsewhere!!!!
By the way Professional Products has a 52mm throttle body for like $200.00 which is another $50-60 cheaper than the Summit stuff....... and $150.oo cheaper than Holley stuff!
http://www.summitracing.com/parts/PFS-69705/
When you think about what the throttle body does, there's really no reason to spend a ton of cash.....
my
Old Mar 5, 2010 | 07:25 AM
wildjyoung's Avatar
Thank you for your very thorough response. It is greatly appreciated!
I have heard a lot of negative things about Professional Products but like you mentioned, the design is relatively simple. So, it should be fine.
The car has not been on the dyno yet because as soon as I got it running it went to the body shop. Wow, sounds like your car does well!!! 330 at the rear wheels is about my goal. I was hoping for 350 but 330 is good enough!
Terrell351
Jun 13, 2021 01:13 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
mdtoren
Aug 23, 2015 12:52 PM
mdtoren
Aug 16, 2015 05:45 PM
bamaboy0323
Aug 15, 2015 07:20 AM
