OEM Roller or Hydraulic flat tappet?
Car: 1985 Camaro Z28
Engine: 355 SD TPI
Transmission: 5spd w/Hurst Short Throw
Axle/Gears: 4th Gen 3.42 LS1 Brakes
Building a new TPI motor, is it worth the extra money to go Hydraulic Roller Cam, or just stick with a Hydraulic flat tappet. I have a 87+ block, but non of the OEM parts. These were my cam choices:
Hydraulic Flat Tappet:
http://www.summitracing.com/parts/CCA-12-366-4/
Hydraulic Roller
http://www.summitracing.com/parts/CCA-08-305-8/
but then I will need:
http://www.summitracing.com/parts/CCA-08-1000/
and this
http://www.summitracing.com/parts/CCA-850-16/
Hydraulic Roller
and this
Car: 91 Trans am
Engine: built 360 TBI
Transmission: built 700r4
Axle/Gears: 10bolt/3.23
Re: OEM Roller or Hydraulic flat tappet?
Hydraulic Roller is the way to go. With some luck, the spider and retainers can be found in the classiefied's or JY.
Did comp cams suggest that cam for a 305? With what heads?
Engine: 355 SD TPI
It's just a cam I chose for a street 355 TPI. I'm a big fan of the xe268 grind.
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
I don't know that an XE268 is going to be very computer-friendly.
Engine: 355 SD TPI
read the first post please, i'm not putting an XE268 in this motor. I'm a fan of that grind and I have chosen two cams for TPI fuel injection based off of that grind from comp cams that is still computer compatible.
I'm trying to get some insight to find out if it is worth it to spend the extra $$$ on the parts I need to go hydraulic roller cam, or just go with a computer friendly hydraulic flat tappet cam.
Engine: 383 Carb
Transmission: 4L60
If your block is machined for it, get the roller.
Car: 91 Trans am
Engine: 355 SD TPI
Going roller would run me over $500 with cam, lifters and hardware kit.
Hydraulic flat tappet will run me about $200, for cam and lifters.
Car: 91 Trans am
http://www.summitracing.com/parts/SUM-150121/
http://www.summitracing.com/parts/NAL-12499225/
Spider kit 82$ +roller lifters 126$ + roller cam 270$ = 478$
Cam button 7$(make sure you can reuse your timing cover if not + timing cover $) + good flat tapped lifters 73$ + tapped cam 140$ = 220$
258$ difference, though im sure you can find a used "spider kit" for much less.
Good luck.
Good luck.
Car: 1986 Camaro Z28 IROC-Z
Engine: 350 Tuned Port Injection, for now.
Axle/Gears: Posi - 3.23
Roller. Bottom line is that you want less friction on all rotating or moving parts that are inside the engine. Now getting into the specs is a different story. If you go too big a cam, you'll have vacuum issues. It's the vacuum that our ECM's monitor (so I heard). If the ECM pick's up a different reading of the vacuum that is out of it's programmed setting, then the ECM will try to correct by making timing and fuel adjustments without knowing that there has been a modification to the cam. You can go big (as in the cam), but now you'll be spending more by visiting the DYNO shop to properly tune and burn a custom PROM chip.
Car: 1987 TransAm Ttop
Engine: 2005 LQ4
Transmission: Ls1 T56
Axle/Gears: 3:54
The easiest way and cheapest way is the flat tappet setup.It will require more maintenance at first from break in.If your on a tight budget there is nothing wrong going this route.You can find a better and easier cam to tune with the ecm.It will also get you the power your after aswell. My 86 block isnt a roller setup but it can be converted but the extra cost is out of my budget to go full roller.Maybe next time.
By the way, TG Goose, nice Camaro. I like the 2 tone paint.
Engine: 355 SD TPI
thanks for the ups on the camaro. I think I might just buck up and go the roller route, the block is already set for it, it will mean less wear on the valve-train over the life of the engine, might as well do it right the first time!
I agree. I went from flat to roller just for the little bit of extra power. When it comes down to a stop light race, every bit of power makes a difference.
Car: 91 Trans am
Well not really if you have a roller block, other then the parts already mentioned earlier, you need to change lifters and add specific breack in oil.
Now if you really count every single $, the better fuel efficiency due to less friction will most certenly allow you to save $'s.
Then comes the wear, after 160k the roller set up will still be like new and can be reused or sold.
Car: 91 Trans am
91TTOPZ
Exterior Parts for Sale
Sep 20, 2016 12:42 PM
skinny z
Oct 5, 2015 06:23 PM
