No power to the injectors. Any ideas?
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
I recently pulled my L98 and replaced it with a stroker. Ive been trying to get it started with no luck and just found out the injectors are getting no power. Its using an accel gen6 ecu that is showing a pulse going out but when I put a voltometer on the harness connector theres nothing at the actuall injector. Any Ideas?
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: No power to the injectors. Any ideas?
the 2 10A injector fuses?
Car: 87 GTA
Engine: 385 sbc
Checked em and there both good. I also checked the ecu and the terminals that need power have it and the ground terminals all show ground. Im assuming there is a short from the ecu in the wires themselves or is there a sensor somewhere that would tell the ecu to not send the pulse out if its bad.... like the iat or map or something?
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
check your ignition module ... are you getting spark?
The injectors should be hot whenever the ignition switch is turned on. When the ecm pulses it creates a ground to fire the injectors. I do not know if it is a stock harness or one specific to the Accel unit but somewhere you are losing voltage between the fuse block and the injectors. Start by making sure you have voltage at the harness connector under the dash and if so it is the harness. If not it is the wiring between the fuses and the harness...
Car: 87 GTA
Engine: 385 sbc
My friend and I found the problem. The ground wires were shorted so we ran 2 new wires from ecu to the harnesses and its all good now
. The battery died before we got a chance to get it running but atleast Ive got fuel, air and spark now.
. The battery died before we got a chance to get it running but atleast Ive got fuel, air and spark now. Thread
mdtoren
Aug 16, 2015 05:45 PM
