87 305 TPI barely runs, dies under throttle
Old Apr 11, 2010 | 02:53 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
So, admittedly the car has sat for a while but I replaced all the plugs, cap, rotor, ignition module, set the timing, put fresh fuel in, and checked the TPS voltage (which was good). Also put two new fan relays in but that shouldn't be germane to the issue....problem is, the car doesn't really want to start, and if it does run and I step on the throttle, it starts to sputter and die out. If I flutter the throttle a few times, it might wind up a bit but it still seems like it's missing or just nowhere near full song.
I'm really afraid I'm going to end up replacing the fuel pump, lines, injectors, etc...before it's all over but I'd like to have it running smooth before I get into all that and at least get to drive it a few times this summer.
Somebody knowledgable, please HELP!!! Thanks all in advance!
Old Apr 11, 2010 | 04:09 PM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
Re: 87 305 TPI barely runs, dies under throttle
hook up a fuel pressure gauge and see what it reads.
should be around 35psi at idle and 43psi when you rev it up a bit.
Old Apr 11, 2010 | 04:47 PM
1tpi's Avatar
Car: 75 Vette
Engine: 406 TPI
Transmission: 700 R-4
Axle/Gears: 373
Did you change your fuel filter
Old Apr 11, 2010 | 06:19 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
28 psi at idle and trends downward when the throttle body is opened. Sounds like a fuel delivery issue.
Old Apr 11, 2010 | 07:09 PM
87IROC-DAN61's Avatar
Car: White 1987 IROC-Z
Engine: 305 TPI LB9, 215 HP
Transmission: Borg-Warner T5 NWC
Axle/Gears: Borg-Warner 7.75 with 3.27 ratio
Hello Charlz B.!!
Pinch the fuel return line, and then apply power to the test connector for the fuel pump, pressure above 47 psi = faulty pressure regulator, pressure below 40 psi = faulty fuel pump!!
Of course you will have tried the fuel filter first!!
Old Apr 12, 2010 | 09:38 AM
jack harrison's Avatar
Car: 1987 pontiac trans-am
Engine: 350 tpi
Axle/Gears: 3;73 with eaton lsd
double check your timing. same thing happend to me a while ago. i had the spark plugs hooked up in the right order but id foolishly put them one position out all the way around the distributor!
Old Apr 12, 2010 | 04:20 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
New fuel filter as of today and still 28 psi at idle and the guage has an seizure if the throttle is opened. It did run a measure better though and put a good bit of water out of the tailpipes but it's still not right. I'll try the fuel line pinch as soon as I have a moment.
Old Apr 13, 2010 | 12:35 AM
Hello Charlz B.!!
keep us posted as to your findings!!
Old May 3, 2010 | 12:05 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
New fuel pump....just what Dr. ACDelco ordered. Was able to change it out and put the car back together in one long saturday. Just had it out on the interstate for a stretch and a fresh inspection sticker. Legal and evil once again! Thanks everyone for the information!
Old May 3, 2010 | 12:07 PM
Charlz B.'s Avatar
Car: 87 IROC-Z
Engine: LB9
Another quick question...while doing this, I managed to shear off one of the track bar bolts. I was wanting to replace all of them with stainless steel ones....anyone have a good source for such hardware?
Old May 5, 2010 | 01:26 AM
Hello Charlz B.!!
Did you try the fuel line pinch to come to the conclusion about the fuel pump?
Curious to see if you used that method, and how it worked for you!!
BlueIroc-Z
Jun 9, 2019 03:22 AM
1nastygta
Oct 28, 2015 08:51 PM
st.evel07
Aug 13, 2015 06:15 PM
squiggy2
Aug 9, 2015 09:30 PM
drathaar907
Aug 6, 2015 04:20 PM
