About what cfm would this intake setup flow?
Old Apr 14, 2010 | 03:59 PM
92GTA's Avatar
I'm trying to figure out a guesstimate on what cfm the following intake setup would flow:
All parts will be extrude honed to the max by ExtrudeHone.com
Accel TPI base manifold
SLP TPI runners
Factory TPI plenum (totally hogged out as much as possible)
52mm TPiS throttle body
Any guesses? I'm eventually going to go with an even larger TB but don't know when or what size. This will all be getting blown by an F1 ProCharger.
Thanks!
Old Apr 14, 2010 | 04:21 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: About what cfm would this intake setup flow?
Total package maybe 240-250cfm. I assume you are using the 2nd design SLP runners.
Old Apr 14, 2010 | 04:49 PM
92GTA's Avatar
I bought them new from SLP in 2001 or 2002 I think because the original ones had been removed by the time I purchased the car in 2000. When did SLP revise the design?
Is that the most I can squeeze? What would a larger TB get me? Or is the stock plenum the bottle neck?
Old Apr 14, 2010 | 05:31 PM
Car: 1989 GTA
Engine: 369 TPI
You have the 2nd design SLP runners. Out of the box they don't flow all the great. Extrude Hone will help but IMHO that is the bottle neck. They need a lot of help with a die grinder. Depending on how far you want to go with welding and grinding they can be made to flow very well with over 300cfm.
Nothing wrong with the factory plenum as it can be opened up to flow more than enough cfm. With work you can get over 300cfm with the parts you have. Dr J opened up an Accel TPI intake manifold to flow over 330cfm.
Old Apr 14, 2010 | 07:17 PM
92GTA's Avatar
Ok cool. Who is Dr J? I tried a user search and couldn't find him. I'd sure like to pay him to work that magic on my manifold! Hmm, that doesn't sound right
So the runners need the most work huh. I don't want to cut them open like some I've seen here but do the most I can otherwise. I don't have any air tools, or grinders, or bits. I wish there was some place I could just send all the parts to...
Old Apr 14, 2010 | 08:04 PM
Car: 1989 GTA
Engine: 369 TPI
Dr. J has a head porting business in our area and that is why we use him. He has become familiar with TPI through us and is impressed with the flow numbers that can be achieved. Here is his website.
http://www.j-performance.com/index.p...d=16&Itemid=30
Old Apr 14, 2010 | 08:19 PM
92GTA's Avatar
SWEET!!! Thanks! I emailed them for a quote so I can send them all my intake parts.
Old May 7, 2010 | 09:11 AM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
did he ever get back to you on a price?
Old May 7, 2010 | 09:24 AM
92GTA's Avatar
Yes, on Monday. I am stopping and selling everything to start another project though.
stalkier
Dec 6, 2015 11:25 PM
beastin91rs
Oct 9, 2015 07:38 AM
formula_novice
Sep 5, 2015 03:58 AM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
