Need close up pics of tpi systems
Old Apr 21, 2010 | 11:09 PM
Duane's 91 Z/28's Avatar
Car: 1991 red Z/28
Transmission: T5 swap
I have a 91 Z/28 (just purchased) with the 350 TPI and want some close up pics of the intake if anyone has some. I just want a visual of where the little air hoses and wires plug into.
Also am wondering if an 89 TPI off a Corvette is the same as a 91 Z/28 TPI because I am told the engine and TPI is off an 89 Corvette as its not hooked up...just sitting in the engine bay so I need to get everything hooked up.
I know nothing about the TPI engines so this is all new to me
Old Apr 21, 2010 | 11:15 PM
juanillox8's Avatar
Car: TOO MANY
Engine: 350 TPI / 350 TBI/6.0L VORTEC
Transmission: T5/AUTO/AUTO
Re: Need close up pics of tpi systems
if you are using a corvette engine you need the harness too otherwise it wont work with the 91 ecm
now is it the hole thing from a corvette or just the block???
Old Apr 21, 2010 | 11:43 PM
Car: 1991 red Z/28
I believe the engine block and the TPI is from the 89 Corvette. So all the plugs and hoses are different from the Corvette to the Camaro?? I believe the horsepower ratings are the same from what I've read online.
Old Apr 22, 2010 | 12:07 AM
juanillox8's Avatar
Car: TOO MANY
the thing is the 91-92 camaro run with a maf sensor and older models had a map sensor, also your tpi might have 9 injectors intead of 8 that came with the 91 harness... we need pics of your setup to see what system you have and go from there also, do u know if whoever sold you the car gave you the corvette ecm and harness??
Old Apr 22, 2010 | 12:15 AM
juanillox8's Avatar
Car: TOO MANY
go to my profile and pictures and take a close look to the tpi and compare it to yours and tell e if looks the same on the runners
Car: 1991 red Z/28
Thanks for the info. I will get some closeups of the thing tomorrow. Uhh no on the harness. The Camaro harness and is still on the car . He just showed me that the harness wasn't cut at all and all the plug ins are all still there. As for the ecm, it should still be there as well. I just need to know where it is.
Old Apr 22, 2010 | 12:18 AM
juanillox8's Avatar
Car: TOO MANY
ok yea it should be there, its located on the passenger side under the dashboard
do you know if the car was 350 tpi to begun with???
Old Apr 22, 2010 | 12:23 AM
Car: 1991 red Z/28
from what I can remember of mine, everything looks the same as yours does. The fuel lines come out on the driver side.
Old Apr 22, 2010 | 12:33 AM
juanillox8's Avatar
Car: TOO MANY
what about the injectors 8 or 9,? was it tpi originally???
Old Apr 22, 2010 | 12:46 AM
Stephen's Avatar
Car: 87 GTA
Sounds like somebody started the swap, realized it was over their head having to change out the ECMs & the whole harness, so they gave up & pawned it off on you as an "easy thing to finish".
While it isn't impossible, you will have to change ECMs & the harness out, to finish it.
Good luck!
Old Apr 22, 2010 | 12:53 AM
juanillox8's Avatar
Car: TOO MANY
thats why i was askin you about the original setup of that car and to find out if it indeed the engine you got with it was from a corvette you need to know for sure what you are dealing with before you start putting it back together to see what direction your doing to take.
Old Apr 22, 2010 | 12:56 AM
Car: 1991 red Z/28
It looks like there are 9 injectors but I will look again tomorrow when I am more awake. Yes it was a tpi originally.
Old Apr 22, 2010 | 12:59 AM
juanillox8's Avatar
Car: TOO MANY
uuuuh 9 injectors not a good sign you need ecm and harness and more likely map sensor.... let us know...
Old Apr 23, 2010 | 12:42 PM
regal301's Avatar
Car: 1988 iroc-z
Engine: 350 Vortec TPI
Axle/Gears: 3.73 4th gen Torsen 10bolt
WRONG
90-92 CAMARO IS MAP
85-89 IS MAF
Old Apr 23, 2010 | 12:45 PM
regal301's Avatar
Car: 1988 iroc-z
there was no 9th injector in 1989
the newer tpi harness will run the older motor,the cold start injector wont be needed.
Old Apr 23, 2010 | 10:01 PM
juanillox8's Avatar
Car: TOO MANY
keep in mind he has a corvette engine 89 corvette didn't use 89 camaro engine...
in order to help him he needs to tell us exactly what he has that way we wont be just guessing
Old Apr 24, 2010 | 08:42 AM
regal301's Avatar
Car: 1988 iroc-z
89 vette and camaro both got the l98
if its a vette motor it will have aluminum heads,if not then its a fbody l98 or lb9 and regardless, the 91 harness will work on any of the tpi motors.
its the same small block that has been around since the invention of the wheel.
im sure he knows what a tpi looks like,so all he needs to do is get the block numbers off the motor behind the drivers side head to determine the displacement.
Old Apr 24, 2010 | 08:48 AM
regal301's Avatar
Car: 1988 iroc-z
i think your confused with the lt1 that came out a few years later
Old Apr 24, 2010 | 09:32 AM
juanillox8's Avatar
Car: TOO MANY
probably but if the motor has aluminum heads he'll need a different prom i know this for a fact i was gonna put aluminum head on my rebuild but i couldnt find a prom for my ecm back then.
Old Apr 24, 2010 | 09:35 AM
juanillox8's Avatar
Car: TOO MANY
any ways... u help him regal i'll go back to the body forum ...
op if you need the pics of the vacuums or harness i have for both cars the 89 MAF and the 92 MAP.
Old Apr 24, 2010 | 09:47 AM
regal301's Avatar
Car: 1988 iroc-z
your right on the prom.
i dont do body work so i wont bother you there
Old Apr 24, 2010 | 09:48 AM
juanillox8's Avatar
Car: TOO MANY
hahaha
Old Apr 24, 2010 | 02:47 PM
Car: 1991 red Z/28
Hey guys, thanks for the info. I have everything pretty much figured out as mine is an 85-88. As far as the intake/tpi unit, the '85-88 intakes have sensors for coolant temp and a cold start sensor for the ninth injector. The '89-92 intakes only have a coolant temp sensor for cold start and coolant temp for the computer. But it's ok, with the right MAP sensor and plugs, it'll work fine with my harness and ECM.
Old Apr 24, 2010 | 03:03 PM
Stephen's Avatar
Car: 87 GTA
FYI....
In 87, they went to center bolt valve covers. So it would be.....85-86, but I thought TPI started in 84 on Corvettes.
Old Apr 24, 2010 | 03:33 PM
Car: 1991 red Z/28
Ok so its at least and 87...if not an 88 because it has the center bolt valve covers...and its a 5.7 L as I just went out to look behind the left head and confirmed it
Old Apr 24, 2010 | 03:59 PM
MFaust89's Avatar
Car: 88 IROC-Z / 92 z28
Engine: LB9 / sbc of a station wagon
Transmission: 700R4 / t5.6
Axle/Gears: i have 2 now!!
Originally Posted by Stephen
FYI....
it started in 85.. in 1984 was the crossfire injection.
Old Apr 26, 2010 | 02:35 PM
Car: 1991 red Z/28
It also has the serpentine set up but I'm not sure if it came off my '91 or the Vette motor. If it came off the Vette motor, the the engine is an '88. But I dont care about what year it is...just so I can get my tpi mated to my '91 harness. And I pretty much have that figured out. I just now want some closeups of the throttle linkage set up, and where the wiring harness runs over or under stuff and to the emissions junk. I just want things to look factory under my hood. Preferibly from a 91 or 92 would be best. Thanks again for all your help guys
gta90
Sep 15, 2015 04:00 PM
beachrodder
Aug 25, 2015 08:05 AM
Street Lethal
Aug 13, 2015 08:28 PM
Sanjay
Aug 12, 2015 03:41 PM
sonu1975
Aug 11, 2015 08:38 AM
