400SBC with a TPI??
Car: 86 Z28
Engine: 350TPI
Transmission: 700R4 lookin for shift kit
Axle/Gears: 3.23???
400SBC with a TPI??
400SB bored .30 over = 406SB
350 Heads. Still holes drilled
RV Cam
Is it possible to use a TPI system with this engine????
What size injectors shud be used????
Any other problems I may run into????
Thanks in Advance!
RV Cam
Thanks in Advance!
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
Re: 400SBC with a TPI??
possible yes, but you'll run out of breath really early. unless you have a good reason to stick with tpi you should go with a shorter runner length, freer flowing system like a mini ram or stealth ram. if it needs to be emissions legal the mini ram now has an EGR kit that will work in most states or you can find converted lt1 intakes
Car: Trailblazer EXT 4.2 (Firebird Form)
Engine: 5.1 4bbl
Transmission: 700R4 Mega Raptor Level 4
theoretically anything is possible... however it might cost you a few more dollars than what you're looking to spend... you will most certainly need porting work on an AFTERMARKET intake, runners and such... along with it you will need a custom tune... yes, even if you go with a MAF setup.. not sure though on the sensors... you may have to get those holes drilled if they''re not already there... you need a knock sensor installed (don't know if a 350 knock sensor will work, most likely though it will)... I've read that externally a 400 is the same as a 350sbc...
Car: 1992 Formula Firebird
Engine: 305CID (LB9)
Transmission: World Class T5
Axle/Gears: 10-bolt, 4.10 gears
Well sort of. 400SB's are always two bolt mains but yeah, externally they are pretty much the same as other Chevy Small Blocks.
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"Is it possible to use a TPI system with this engine????"
Sure, but if you want to make some serious horsepower with TPI you need to do what we are doing here in SoCal. We are talking aftermarket parts. How much power you want to make will depend on how much money you want to spend on the porting. We have units flowing well past 300cfm which will support 600hp.
Car: 1985 Camaro IROC
Engine: 350 tpi
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
One more question!?
Well thank you guys! Looks like I have some thinking to do. I know I will get more power from a carb.. So with the setup I have I was thinking a AIR GAP intake, and a edelbrock thunder series 800 w/ electric choke. Wud that be tooo many cfm????
Engine: L98 and L03
Re: One more question!?
that is a common misconception but EFI has more power to offer and better efficiency. it's just more expensive and a little harder to work with.
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
EFI meaning aftermarket fuel injection?? or a TPI setup?? Because I have a TPI setup of a.. I wanna say 85 Corvette... It has 27# injectors. Correct me if I am wrong. W/ the wiring harness and computer
Car: 92 sonoma
Engine: 1985 LB9 tpi, stock
Transmission: NV3500
Axle/Gears: g80, 4.11 posi
i just found a 400, for a great price, and i was wondering if this would be possible... if i have the 85 style(it says 84 in the production code on the plenum) would it bolt right down, or would i have to drill the holes to fit...(i wanna run tpi also)?
might save up for hsr but will they fit....
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
Car: 92 sonoma
idk... i'm new to the v8 world lol i havent bought it yet, wanna make sure im not buying crap...i've been looking at the weiand sr (similar to hsr) and it says it will bolt up no prob...but its going into an s10... i just got my 305 tpi running and i want to build something "real" for the truck.... i think a 400sb should look good, sound good, and be all that i need for the 1/4...
Car: 86 Z28
Engine: 350TPI
Axle/Gears: 3.23???
Yeah I agree! Your gonna need at least 30# injectors. Hawksthirdgen.com has them.
Engine: 350 tpi
as long as you get the right style heads for the intake you will be fine. in 87 they changed the angle of 4 of the 12 holes that the intake bolts up to. if the intake is an 85 and you get pre 87 style heads you are fine, if you get 87 or newer heads the intake manifold will need to be drilled.
Car: '88 MOnte Carlo SS
Engine: 406 sbc
Transmission: 2004r
Here's a good recent post from montecarloss.com...
http://www.montecarloss.com/communit...=789756&page=1
I have a Holley Stealth Ram setup Iv'e been working on. '88 SS 406 sbc w/ Brodix Track 1's, Comp XE274, Holley stealth ram. Still fixing leaks and tuning but it's getting there.
http://www.cardomain.com/ride/299893
Engine: L98 and L03
the intake should bolt right up. if you get aftermarket heads unless you specify the 88 up intake it will be the standard design
evilstuie
Jan 9, 2020 08:29 PM
Sanjay
Aug 12, 2015 03:41 PM
