My GTA's Future Plans :D
Old May 3, 2010 | 03:31 PM
itsMikey's Avatar
Car: 89 GTA/93 S13/91 Si
Engine: 5.7 350 TPI
A B C 1 Part Part Number Cost 2 Optima Red Top Battery ULT-9022-091 $159.99 3 Jet TPI Air Foil JET-63100 $52.95 4 58mm BBK Throttle Body BBK-1539 $319.99 5 Edelbrock High Flow Runners EDL-3870 $332.95 6 Hawk HPS Brake Pads HWK-HB111F-610 $101.95 7 Eibach Sportline Springs EIB-4-0138 $229.95 8 BMR Strut Tower Brace BMR-STB003H $109.95 9 HyperTech 100 Thermostat HYP-1000 $4.95 10 K&N Oil Filter KNN-HP-2002 $10.95 11 A/C Delete Pully RNB-34157 $24.95 12 Comp Cams Lifter Roller Cam Kit CCA-GK12-600-8 $879.95 13 Fel Pro Head Gasket's FEL-501SD $25.75 14 Powermaster 140amp Alternator PWM-47861 $161.95 15 Doman Window Motors RNB-742-150 $39.95 16 Strange Eng. Front Brake Kit STR-B4118WC $687.95 17 Auto Meter Pillar Gauge Pod ATM-10200 $26.88 18 Bilstein Shocks BSN-F4B461021H0 $82.95 19 Bilstein Struts BSN-F4VE3C522H0 $301.99 20 UMI Sub Frame Connectors UPI-2400-R $199.95 21 GT Styling Tail Light Covers GTS-GT034 $81.99 22 Flex-A-Lite Rad Fan Combo BCI-56484 $899.95 23 Trans Am TB Plate MBA9031411 $38.99 24 Dart Performance Heads DART-10121111x 2 $1,038.00 25 Iridium Spark Plugs ACD41-985 $64.00 26 MSD Ignition Box MSD 6420 $226.60 27 Holley Stealth Ram Intake Manifold W/ Fuel Rail Kit WND7540 $429.00 (+$249.00) 28 WS6 Ram Air II Hood W/ Air Box and Filter HT-RH100 $510.00 (+$210.00) 29 Clear Side Markers CV85CM-0512BLX $50.00 30 Headlight Repair Kit 508210A $35.00 31 Fourth Gen Fiberglass Wing GT-RS180 $399.00 32 T-Top Weatherstripping Kit GM-4133OER $259.00 33 24LB Bosch Injectors BOSCH24lb $329.00 34 T-Top Headliner ABS AFH12C $179.95 35 Black and Tan Seats Hawks4PeiceSet $1,000.00 36 Mickey Thompson Radials 255/50R/16 MTT-3793R $180.95 37 2006 C6 Rims C6206 $959.00
was a spread sheet...so...tell me what u guys think
Old May 3, 2010 | 04:50 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: My GTA's Future Plans :D
That will be some car. It only takes money. Hahahaha.
Old May 3, 2010 | 04:51 PM
1970 Buick's Avatar
Car: 1989 GTA
Cool ideas. I could find 50% or more of that stuff used for way better prices. Check around the boards and save yourself a boat load. GOOD LUCK!
Old May 3, 2010 | 04:54 PM
Guest
Guest
Posts: n/a
Red Top=Garbage
Jet air foil=Garbage
BBK 58mm TB=Garbage... well, can be. I'd buy the Holley version first after what I went through with BBK.
Edelbrock runners=I'm sensing a trend here. Find a different brand.
Eibach Sportlines=Are you sure? It'll sit real low, and theres better options. Just need to do more legwork to find them and pick them.
Hypertech Thermostat=Waste of $
K&N filter=To each their own, I guess. I'd spend less on a Wix or Purolater.
Comp Cam kit=Thumpr? I wouldnt.
Fel Pro Head Gasket=I'd buy the MLS instead.
Strange Eng. Front Brake Kit=Planning on a race only car?
Flex-A-Lite Rad Fan Combo=Thats a lot of $ for something you shouldnt need.
Iridium Spark Plugs=Waste of $
24LB Bosch Injectors=Contact southbay or IFC and get the Bosch III for less.
Questions:
HSR? Then you do not need the runners above.
Is your alternator bad?
I would choose a different cam. I will not pick the heads for you, but they're a small port (180cc) head and I do not see the heat crossover/EGR hole so even if you modify the HSR to run an EGR valve so you can pass smog, the heads dont have the hole you need. At that price point, there is probably a better choice out there. I dont think this is going to be a race only car from the other items listed, so forget the brakes you have listed. Do a 1LE/LS1/C5/C6/whatever brake swap instead. That electric fan setup unless yours is bad and you feel like blowing 900 bucks is just eye candy. Maybe thats what you want to do, I dunno.
As far as garbage goes, I've been through a few Red Tops and I would not even take one for free. They're overpriced overhyped junk that cant handle living in an occasional driver for a year. I've had a normal battery in that same car for 2 years since then and its been a complete non-issue. Optima=junk. Same for that Jet air foil, it fits in the TB rubber tubing and cant possibly do a thing, not to mention that BBK or Holley TB already has a formed in airfoil making that Jet thing useless. I had some idle issues with my BBK TB, apparently that was the result of the following:
No note in the box to not remove the spray paint on the back of the throttle blades
I'm just guessing, because in sending that back to BBK and finally getting it back from them after taking a lot more time than they promised... and MULTIPLE contact attempts on my part, I do not know what they did, nor why. I just know there was some hackjob painting applied to the back edge of the throttle blades when I got it back. Its ok now, but I would never buy from them again.
It might help if you told people what your intentions were with the car as well. Couple things conflict, like the Hawks pads and Strange brake kit, and the Edelcrock runners and Holley Stealth Ram.
Old May 3, 2010 | 05:27 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
WOW! thanks max and thanks everyone else...
to max:
im definitely gonna "listen" to your words of wisdom..i appreciate it!!
Old May 3, 2010 | 05:53 PM
Guest
Guest
Posts: n/a
No problem.
So whats the plans for the car? A look? A sound? Just a fun driver?
Old May 3, 2010 | 06:35 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
just lookin to make it a fast, good looking car. nothing to crazy.
lookin for a good 300-400 hp...
want it to sound like a beast :P lol...wanna be heard up the block.
Old May 3, 2010 | 06:55 PM
1970 Buick's Avatar
Car: 1989 GTA
Spend $150 bucks on an electric exhaust cutout and a stainless y pipe. Hands down the most "fun" thing I have done to my GTA. Nothing makes me smile more then sitting at a stoplight next to some fart can Honda and pushing the switch to open up my Smallblock. The look on their faces is priceless.
Old May 3, 2010 | 11:13 PM
itsMikey's Avatar
Engine: 5.7 350 TPI
haha..yeah my dad has a 06 GTO with a H pipe with dual electric cutouts..funniest thing is when u go to the next light and its quiet again xD
MantyZ28
Nov 8, 2015 06:54 PM
Nick McCardle
Sep 10, 2015 08:36 PM
machinist21
Sep 5, 2015 03:03 PM
