Running really cool
Old May 3, 2010 | 10:37 PM
puddingmmmmmmmm's Avatar
Car: 05 CTS-V
Running really cool
Are there negative side effects from an engine running extremely cool?
Old May 4, 2010 | 09:38 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Running really cool
Excessive engine wear and bad fuel consumption for one
Old May 4, 2010 | 10:48 AM
naf's Avatar
naf
Car: 1987 SC/1985 TA
Engine: 350/vortec/fitech
Axle/Gears: 3.27 9-bolt
Yes. If the oil doesn't get above the boiling point of water and stay there long enough, water will stay trapped in the oil and form acids and sludge. Water vapor is a product of combustion.
That's why it's also important when infrequently starting up a car (while in storage, etc.) to let it run long enough for the oil to reach temp.
Old May 4, 2010 | 10:52 AM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
it will also run rich because the computer thinks it's still warming up.
Old May 4, 2010 | 03:36 PM
Car: 05 CTS-V
What is a typical cause of this besides the thermostat sticking open. I'm pretty sure that's not my issue because it's pretty new.
Old May 4, 2010 | 04:10 PM
naf's Avatar
naf
How are you determining that it's running too cool?
Old May 4, 2010 | 04:16 PM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
it sounds like a bad thermostat to me. I've also seen it not seal correctly and let coolant by. Also if you're not firing on all cylinders it will do that too. My car was only running on 6 and it never got above 120 because the empty cylinders were acting like an air cooler. Car should run REALLY rough if that's what's going on
Old May 4, 2010 | 04:19 PM
STEWARDORNG's Avatar
Old May 4, 2010 | 05:27 PM
Car: 05 CTS-V
Right now my tempature gauge on my dash. I don't have an infrared thermometer to check right now. I'm guessing like most things on my car, the temp gauge is prone to failure? And my car isn't running rough, if this information is any helpful.
Old May 4, 2010 | 05:44 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
How cool is cool? What temp are you running or plan on running?
Old May 4, 2010 | 10:54 PM
Car: 05 CTS-V
looks to be about ~140 degrees, take it my temp gauge is working properly
Old May 5, 2010 | 07:22 AM
naf's Avatar
naf
That wavy thing with the pointer on your dash provides no accurate information on the actual state of nature at the end of its sensor.
Old May 5, 2010 | 07:45 AM
wyochimneysweep's Avatar
Car: 92 chevy 1/2 4 wheel drive
Engine: 5.0L with TPI
I had to much water flow bypassing the theromstat through the heater on a tpi I swapped one time and it would warm up . ran very cold
Streetstuff
Carburetors
Sep 7, 2015 02:33 PM
TheExaminer
Aug 26, 2015 04:59 PM
Bryan F
Aug 18, 2015 02:28 PM
sreZ28
Aug 14, 2015 07:48 PM
Leggman1
Aug 6, 2015 04:15 AM
